C63 AMG (W204) 2008 - 2015
Alignment after rotor and brake replacement?
Old Jul 9, 2023 | 02:58 PM
vinnan's Avatar
E
I just finished changing the rotors and brake pads (DIY). However, I've noticed that the steering wheel points slightly to the right by 2-3 degrees. It's a mild issue, but it becomes quite annoying while driving. I'm wondering if I made a mistake during the brake job or if an alignment needs to be done after completing a brake job.
Old Jul 9, 2023 | 03:33 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
I would uh check your lug bolts make sure everything is attached properly and that you didn't switch tires L/R if you've established a particular wear pattern in one of them
i doubt you separated any ball joints or cranked on the tie rod adjusters
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
