C63 AMG (W204) 2008 - 2015
JACK PAD when jacking from front?
Old Nov 15, 2023 | 03:32 PM
2012_C63AMG's Avatar
C63 AMG
SORRY I tried looking on here and couldn't find anything. I just need to go under the car to fix my engine splash cover real quick (it's falling off). I am going to jack the car up from the front center right where it is falling off. Do I need to use a jack pad for this spot? If so, any recommendations for which jack pad to use?
THANK YOU so much!!
Old Nov 15, 2023 | 05:11 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
There should be a jacking pad in between the front and center splash guards.
I Use mine all the time when jacking the front.
Sometime that pad gets damaged or falls out after damage.
Old Nov 15, 2023 | 05:33 PM
C63 AMG
Ah yes that's where I want to jack it up from.. I didn't realize that was made out of rubber so THANK YOU for your reply!
Side Note: Do you or anyone know where to buy the CENTER SPLASH GUARD? Mine's all busted up!! :[
Old Nov 15, 2023 | 09:37 PM
Cwagon's Avatar
It’s more like hard plastic than rubber but still is the front centre jacking point.
Fir the splash guard try ringing some auto dismantlers/wrecking yards
Old Nov 16, 2023 | 02:26 PM
6_Myles's Avatar
1998 E300TD
It also has a habit of getting stuck inside the jack pad of a floor jack, so don't be too surprised if it pops off when you let the car down, or pulls the jack head off the floor jack...I've had both happen.
