C63 AMG (W204) 2008 - 2015
New Member & Fitment Question
Old Jan 17, 2024 | 05:58 AM
jayanikkal's Avatar
Mercedes Benz W204 C63 AMG Sedan
Good day, all
I trust you are all well.
My humblest apologies if I have not followed the forum due processes.
In a bit of an emergency and need to order a full set of wheels for my W204 C63 AMG Sedan Facelift (base model). Long story short, one of my wheels got damaged and I've been informed by my local dealer that these wheels have been discontinued.
I would like to order a set of VWR V710 wheels. Before I place the order, I'd like to confirm whether they will fit.
Specifications are:
1) 5x112 Bolt Pattern
2) 66.6 Bore
3) Front:19 x 8.5 +35
4) Rear:19 x 9.5 +45
Car is on stock ride height and the current OEM wheels are wrapped in Michelin Pilot Sport 4S tires (235/35/19 front and 255/30/19 rear).
My questions are:
1) Will it fit without any modifications and on stock ride height?
2) Will it achieve a slightly tucked look?
Thank you in advance!
Regards,
Justin
Old Jan 17, 2024 | 03:10 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
They will fit fine with the little back tires that come standard on W204 C63's.
I run 255/35x19 on the front with same front measurements.
Also check here for lots of different tire/wheel dimensions and pics.
Aftermarket wheel Thread. - MBWorld.org Forums
Old Jan 24, 2024 | 12:13 AM
dattorob's Avatar
AMG C63 W204
also refer to owners manual under 'wheel and tyre combinations' , it has detailed breakdown regarding OEM fitment. One of the other considerations is making sure the brakes have adequate clearance especially the front wheels.
