2014 Distronic diabled
C63
Hello,
Newbie to the C63 world.
I've serches thru the manual. I've searched online but only see posts on 'Inoperative' and not 'Disabled'. 2014 123K miles, when i start off in the morning distronic cruise control works, but after a few minutes it shuts off. When I try to select it I get a yellow message 'Distronic disabled'. Everything else works perfect, lane change assist, Nav...etc. I do not get a message 'Aux Battery'. Is it the Aux battery or the actual sensor? Any ideas what to check, measure before replacing parts? Any help appreciated, BL
C63
Yup, I get it. I have a simple scan tool that I diagnose trim levels. 02 sensors ..etc, on my truck, i haven't tried it yet but I'm guessing I need a unique scan/code reader to diagnose this issue? If that's the case, which one are you guys using? Thx for response.
I use a Xentry , but Chris Sullivan (youtube channel) uses these with success
Foxwell Scanner (small one): https://amzn.to/48uMwCA
Maxicom MK808 Scanner (the big one): https://amzn.to/3UR0T0U
C63
also SGR - radar Sensors Control Unit
5304 - radar sensor 3 is distrupted by interference from an external source
5204 - sensor 2 as above
727C00 CAN Bus: one or more signals sent from control unit N30/4 (electornic stability program control unit) via the CAN Bus is implausible
C343800 - the power suppy is outside the valid range
