C63 AMG (W204) 2008 - 2015
Fuel trims
Old Mar 1, 2024 | 01:20 AM
eashwar63's Avatar
C63 AMG SEDAN 2013 (PP)
Fuel trims
Can somebody please tell me if my fuel trims are correct or pulling more…. Facing rough idle issues
Old Mar 1, 2024 | 08:31 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Any mods, row air boxes different filters?
Old Mar 1, 2024 | 09:31 AM
eashwar63's Avatar
Hi,
installed a supercharger and been facing rough idle issue….
Old Mar 1, 2024 | 04:33 PM
eightysixtuned's Avatar
W211 E63 AMG
trims are moving a lot more than they should but the amount they're moving isn't really out of spec.
Old Mar 1, 2024 | 05:38 PM
W211 E63 AMG
trims moving as much as you're seeing, you have a mechanical concern (dirty MAF sensors, failing map sensors, failing oxygen sensors, etc) or your supercharger tune is not mapped correctly and its causing the ECU to overcompensate in both directions as it does not know how to control the idle as the mapping done is not correct.
Old Mar 2, 2024 | 11:20 AM
eashwar63's Avatar
What do you mean by mechanical concern sir? Yes will be cleaning the MAF sensors and will O2 sensors…..Yes I have raised this issue with tuner also…
thanks for reply.
