C63 AMG (W204) 2008 - 2015
2009 C63 push start smart key. Is not too smart
Old Apr 18, 2024 | 09:25 AM
Thguns's Avatar
2009 Mercedes C63 AMG, 2013 Mercedes C350 4Matic Coupe. 2012 GLK 350 4Matic
Wife parked car, go out next day no start, either fob.
checked main battery, was at good 58% on tester, old battery. So replaced. Replaced battery in fobs, in the car. Still nothing. Checker antenna fuse 7.5 amp, good fuse.
what’s active when get car:
Speedo lights up, lock unlock, trunk all work and the radio works. Windows don’t work
steering is NOT locked!
key for seem to be ok with flash red when buttons activated. Infrared tests out ok.
took the shifter out of park and pushed car. Nothing. Have Not checked brake light switch
while messing about one fob flashed out a repeated code on red light on pause, then 5 flashes. Couldn’t find anything about this
suspecting the ESL. has gone!
is there anything else I should be checking doing before I have it towed 300 kilometres to Mercedes Thanks
Old Apr 23, 2024 | 11:42 AM
Thguns's Avatar
Update on 2009 c63 no start
well yesterday I called for a tow to Mercedes, just for THOI I went out and the car started, all normal bells, whistles, wirrz everything worked, stopped and started about 20 times so far. Perfect. Now here is something I had Not noticed, when not starting, pressuring on the brake petal was rock solid. How when I get into the car the first thing I do is press the brake pedal, and it is normal in that it move down to firm. I’m still going to take into Mercedes for a check up. Comments very welcome. Maybe the car got scared when it heard me say it getting towed. Fixed itself. LOL
