C63 AMG (W204) 2008 - 2015
C63 - Rattle from front suspension after replacement of all wishbones
Old Jun 14, 2024 | 12:37 PM
amgfreak87's Avatar
Hi,
This week, I got the upper, lower wishbone and tie rod ends replaced. In addition, I got the camber correction bolts installed as well, to reduce the negative camber due to my HR coilovers.
Unfortunately there is a rattle at slow speeds although all bolts were tightened to spec in the loaded position.
Any ideas?
Old Jun 19, 2024 | 09:54 AM
amgfreak87's Avatar
Solution:
Toe was out of spec due to one camber correction bolt not being in place properly on one side. I had fixed the bolt, but the rattle remained.
The second alignment magically fixed the issue.
Hope this helps anyone, as all bolt were tightened to spec.
