Headlight LED Dotmatric code - Hlep
I ordered a new ballast unit and installed it, it's no longer tripping the 32 A fuse and main & high beam is now working; however, the headlight side indicator and low beam is still not working!
The OBD diagnostics shows headlight faults - U118B87 "communication with control unit - right headlamp range adjustment.
My suspicion is that either ;
one of the other two headlight ballast units (side &top) are also defective
or
the headlight needs reprograming
or
both
I would like to try reprogramming however the LED Dotmatric code is damaged and unable to scan, I can scan the smaller C code ok . I need this code to complete the programing, does anyone know any other work arounds or have any other suggestions? Access to Mercedes configuration VDOC data for my vehicle ?
Headlight part no A205 906 95 01
bar code 0 301 264 631 01 12 15 668 I believe the 01 12 15 is the date of manufacture ,
Car Vin code
WDD2050452R158592
Any help would be most appreciated
Regards
