2010 C63 Engine starts then turns off after 2 seconds. HELP!!
Need help!! Was on my way home and out of nowhere car went limp and lost power. Weird sounds started coming from the engine and when turning the wheel there would be a screeching sound coming from the engine. As of now when starting the car noises come from the engine and turns off.
Sounds like the bearings are wiped out. Drain the oil and see what it looks like or pull the oil filter out and look for metal glitter in there . But again sounds like internal damage but hearing it through a video it's difficult to properly diag it.
have you scanned it for any CEL codes? Does sound terrible, also sounds like it has exhaust manifold leak.
Had 2 codes pop up on the engine. - The intake manifold pressure sensor has a malfunction. This is the first time the code popped up but after clearing it, cleaning the map sensor and starting the engine again didn’t show up.
- The position sensor of the intake camshaft (cylinder bank 1) has a short circuit to positive. After clearing all the engine codes the only one that would come back is - The position sensor of the intake camshaft has a malfunction.
