C63 AMG (W204) 2008 - 2015
Inconsistent misfiring in idle/drive/reverse below 1500rpm - no engine lights
Old Jan 26, 2025 | 02:23 AM
cyasomeday's Avatar
C63 AMG P31
Hi everyone,
I am a bit puzzled by a recent issue that has come to light following the replacement of my spark plugs, ignition coils, and an intake cam adjuster.
I had the parts replaced to deal with severe misfiring and the car now drives well, save for the revs fluctuating by up to 200 rpm when idling, or accelerating/reversing which can be felt in the cabin (likely misfire). However, the fluctuations are not consistent in timing. There are no engine lights on the dashboard when it happens.
For some preface into symptoms/current diagnosis:
  • The fluctuations only seem to appear below 1500ish rpm. Example, when accelerating slowly I would feel two to four misfires until the revs went above 1500ish rpm
  • The car has returned a P0030 misfire in cylinder 3 code which appears and disappears at random - sometimes it does not even appear. No other codes are thrown such as a "lean" or "rich" fuel code.
  • For about 3 weeks before the repairs, the car sat under a tree due to severe misfiring now fixed with new sparkplugs and ignition coils, and our initial thoughts have been to clean out the MAF sensors and the air intake filters which has not helped.
  • The MAF sensors have been tested and appear to be running fine.
  • The car otherwise drives fine.
Today I applied fuel system cleaner and shortly afterwards while sitting at traffic lights, the idles revs jumped about 500rpm and then the issue did not return for the rest of the 10 minute drive, which also included spending some time sitting in park and in gear but with my foot on the brake and there was no misfiring.
When I took the car out later in the day, I did have two singular misfires (within the same rpm range). Idle misfires were not apparent. Then, when I parked my car, I was in reverse gear and with my foot on the brake and the car was misfiring consistently without throwing a code. When I put the car into park, the misfires stopped.
I have done some looking online and through the forums and have identified the following potential issues:
  • Vacuum leak
  • MAF sensors
  • Air filters
  • O2 Sensor
  • Fuel injectors
  • Fuel rail pressure
  • PCV valve
  • Air Conrol value
  • Carbon buildup
  • Spark plug seating/gap
  • Timing
  • Throttle position sensor
  • Throttle body
  • Clogged EGR valve
Has anyone had the same sort of issue before and if so, what was the culprit?
Thanks everyone!
Old Jan 31, 2025 | 03:41 PM
dattorob's Avatar
AMG C63 W204
may seem obvious question, but is it always cylinder 3?
Old Feb 1, 2025 | 08:45 PM
AMGSPY's Avatar
2014 C63 507 Coupe
How many miles? Injector?
