C63 AMG (W204) 2008 - 2015
AC compressor replacement
Old Mar 19, 2025 | 09:24 PM
SICAMG's Avatar
2005 e55 AMG
My sons 2012 C63 coupe needs a new ac compressor,making a bearing noise all the time. Anyone replaced one and have some tips/tricks to remove/replace ?
Nothing I can't do but will not be doing it at my garage, I have to go to his place far away so want to have as much info before the road trip there.
Can't find any videos on doing it but know it should take around 2.5 hours ??
Old Mar 19, 2025 | 11:57 PM
roadtalontsi's Avatar
10 C six trizzle
you'll need e12 or r14 for the 3 compressor bolts. I typically like to use a very long 1/4" extension with a 4 or 5mm allen wobble socket for the bolts holding the lines on the compressor. Fan will need to come out. There's not a lot of space but it's not too bad if you have some ability to wrench.
Old Mar 20, 2025 | 03:15 AM
ygmn's Avatar
2015 E400 Sedan
need vacuum pump set of gages.
Change belt and any idlers and tensioners too while you are at it
Old Mar 20, 2025 | 07:31 AM
SICAMG's Avatar
2005 e55 AMG
Awsome thanks. Have pulleys, belt and compressor already and was going to get the underdrive crank pulley but decided wasn't worth it and and will spend his money and replace the injectors instead since he's at 60k for miles.
When looking at it I thought maybe the compressor was coming out the bottom since it is so tight in there. Good to know it's coming out the top !
Old Apr 13, 2025 | 05:47 PM
eocarter's Avatar
2011 C63 AMG Eurocharged 93 tune, Agency power headers and Sect 1 mid, innotech ipe sect 2 mids
I have to replace my 2011 C63. So how did you do it?
Old May 1, 2025 | 10:36 PM
C63 UK's Avatar
C63 W204
fair enough however i feel like crank pulley upgrades are underrated. And we'll worth it for the price they go for nowadays. Once I get my car sorted out I will be getting one for my c63
