C63 AMG (W204) 2008 - 2015
2012 c63 4 door amg w204
Old Apr 7, 2025 | 11:15 PM
fariss's Avatar
2012 c63 amg
i have 2012 c63 amg wide body what rear wheel setup can i do for mickey thompans i think the smallest wheel i can fit is an 18 inch but im not sure what offset i can run and my rear rims right now are 11 inch in width and 19 inch wheel in the rear
Old Apr 9, 2025 | 09:32 AM
Vic0n's Avatar
Mercedes CLA 250
Sweet ride, bro. Yeah, you’re right, 18s are usually the smallest you can go on the C63 because of the brakes. If your current rears are 19x11, you could go with 18x11 or 18x10.5 for the Mickey Thompsons. A lot of people go with 305s or even 315s depending on the fender clearance. Offset around +50 seems to be the sweet spot to avoid rubbing, but might still need some fender work depending on tire bulge.
Old Apr 12, 2025 | 01:15 AM
roadtalontsi's Avatar
10 C six trizzle
If you cut the nubs off the rear brake pads (for quick change and vibration frequency mass) you can clear very specific 16" wheels and almost every 17" wheel. As for offsets it will be unique to your car being that it's aftermarket. 18" wheel up front is minimum. not all 18" wheels will clear the fronts.
