Help with high temps ‘13 c63
Also if this sounds normal what would you consider abnormally high temperatures? For reference it’s about 80 degrees+ every day here and when driving on the highway it’s as low as 218F
P.S. You changed your adjusters and didn't change the tappets when in there? You are going to do double the work later
overfilled?
5w40?
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
