C63 AMG (W204) 2008 - 2015
722.9 MCT rebuild
Old Dec 1, 2025 | 09:07 PM
sbaer's Avatar
2011 E63 M156 :) - previously: 2016 GLE63 with U21 (missed); 2012 ML550 , ML63 2009 - E550 W212 2010
722.9 MCT rebuild
Repost from the W212 forum. Same transmission in C63 with the switch off the torque converter.
2011 E63; 60k miles. When transmission is warm, juddering when accelerating from a stop in the first few gears. Worse on a hill and also in reverse.
Also noticed that rpm fluctuates a bit when driving and in D mode at a light the car something feels a bit light it wants to go.
Transmisson oil/filter replacement done. Got a bit better. Shift adaptation done and got a bit better.
But often times it still looks like I am driving a stick and don’t know how to.
Indy that only works on MB isn’t convinced a full flush would solve my woes.
$4K for pulling transmission, replace wet clutch pack and one solenoid. I’ll get a second quote but this seems reasonable.
They are not a transmission shop however, and they acknowledged this work would be as far as they can go.
My question is, does anyone know a shop in NC, SC or MD who is really good working on the MCT for a more all rounded transmission service?
Old Dec 2, 2025 | 08:25 AM
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
At that price, just got with a built trans from SHR and have it be bulletproof for many years.
https://southernhotrod.com/shr-merce...ssion-type-ii/
Old Dec 3, 2025 | 04:03 PM
BalanBro's Avatar
2012 C63 P31 Sedan
Are you tuned? Several OTS tuned cars have exhibited this behavior under low and part throttle. It's usually because they mess with torque management. I had this issue, and it was completely resolved when I switch to a different tune (originally had an EC tune).
Old Dec 3, 2025 | 09:33 PM
sbaer's Avatar
No known tune. Any idea how I could verify? I guess only the dealer could do a checksum review of the ecu.
Second shop confirmed that this issue is usually only seen at higher mileage. Their price out the door wet start-up clutch replacement including shift adaptation and one solenoid replacement (more if needed) is $2800. That sounds more reasonable for 5-8 hours of work and parts. MB clutch is $850, solenoid $130.
