C63 AMG (W204) 2008 - 2015
Heat Exchanger for supercharger build
Old Dec 25, 2025 | 05:46 PM
C63 UK's Avatar
C63 W204
Hi,
I'm going to suoercharge my 2009 c63 and was wondering what heat exchanger options there are for my build/car if I do not go with a kit (like weistec for example) that includes it.
Are the aftermarket m113k heat exchangers any good??
Old Dec 26, 2025 | 05:06 PM
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
You can order a Weistec heat exchanger and trunk tank separately without the supercharger. That's what I'm running on mine, it mounts to the OEM oil cooler.
You can also order a larger one from VRP/PTG but you'll have to install it in the upper radiator area and fabricate some brackets.
Old Dec 28, 2025 | 06:34 PM
C63 UK's Avatar
C63 W204
Thanks, much appreciated!
Old Dec 29, 2025 | 03:37 AM
eashwar63's Avatar
C63 AMG SEDAN 2013 (PP)
[QUOTE=C63 UK;9247601]Hi,
Are the aftermarket m113k heat exchangers any good??[/QUO
If u are worried about IAT then look into fi inter chiller, taps into your AC lines and cools the water temps to -2 C, with this setup you don't need a heat exchanger.... I have been running this setup and haven't faced any issues.
