C63 AMG (W204) 2008 - 2015
M156 codes
Old Jan 27, 2026 | 06:59 PM
ltsm's Avatar
c63 w204
M156 codes
I finished assembling the car yesterday and these codes came up. What did I do wrong? The timing tool has a good reputation on Amazon. The car doesn't stall, but while driving it wants to shut off and then goes back to normal. What could it be? What should I do? Do I need to do anything with the Xentry?
Error Codes
2069
“The outside temperature sensor has a short circuit to the positive pole.”
3699
“The fuel rail pressure sensor has an irregularity in operation.”
0271
“The intake camshaft position (bank 1) differs from the nominal value.”
0275
“The intake camshaft position (bank 2) differs from the nominal value.”
Old Jan 27, 2026 | 07:16 PM
Cloudini5's Avatar
C63 AMG (2008) and 190E EVOII
Did you reset all the adaptive values in xentry afterwards? Im not totally sure but i believe you can let the car relearn and also reset the camshaft positions, please correct me if im wrong
Rest are probably old codes, outside temp doesnt interfere with your issue, fuel pressure can!
Old Jan 27, 2026 | 07:18 PM
ltsm's Avatar
c63 w204
I didn't do that, I just turned it on, it started malfunctioning, and I erased all the stored and current codes.
Old Jan 28, 2026 | 03:27 PM
Arnav's Avatar
2013 Mercedes-Benz C63 AMG (C204)
Where is the relearn/camshaft position in xentry?
