C63 AMG (W204) 2008 - 2015
Wheel offset question
Old Feb 4, 2026 | 04:57 PM
LSAMG's Avatar
2013 C63 AMG Sedan
Hey guys,
any one running the following setup? and gotchas to look out for, concerned it might not clear the calipers
18x8J Front Offset 40
18x9J Rear Offset 45
Old Feb 23, 2026 | 11:28 PM
dattorob's Avatar
AMG C63 W204
should do as 18" wheels are an option also depends on wheel, more chance with a forged wheel.
OEM wheel sizes and offsets (same for 18” and 19”)
- Front is 8” width with +45 offset, rear is 9” with +54 offset
- C63 hub center is 66.6mm
- Bolt circle is 5 x 112 mm (corrected)
Old Feb 28, 2026 | 08:44 AM
LSAMG's Avatar
2013 C63 AMG Sedan
thanks
Old Feb 28, 2026 | 09:26 AM
streborx's Avatar
Top Answer: 1
G550
Offset is a measure of distance between the wheel's mounting surface and its centerline, and determines the lateral position of the tire and wheel (and therefore where the tire's outside edge will sit with respect to the fender lip). The clearance between the wheel's mounting surface and brake caliper is fixed (it's the same as the surface of the hub to the caliper). Lay a straight edge across the hub and observe the distance between it and the caliper. It's always the same no matter where the wheel's centerline is. The wheel's inside diameter clearance to the outside surface of the caliper is the critical dimension and limits how small the wheel you can mount.
Old Feb 28, 2026 | 06:56 PM
AMGSPY's Avatar
2014 C63 507 Coupe
I used 18 inch wheels off an E550, (2013 I think), and they are fine. They are on the car now so I'm not sure exactly, but they were not staggered like my C63 and were in the 45 - 48 range offset range. They look fine and work great for my snows. They are also softer over bad roads as a plus.
Old Mar 1, 2026 | 08:51 AM
DRBC43AMG's Avatar
For winter tires, the factory recommends a square set-up with 18" in 8J and ET45
