C63 AMG (W204) 2008 - 2015
Code P3628
Old Mar 9, 2026 | 07:46 AM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
Code P3628
Got an engine warning light shortly after starting up my C63 after a week or two of non usage.
Got my iCarsoft scanner out and ran the fault codes and came up with a P3628 indicating a "B4/15 (Fuel pressure sensor) has an open circuit or short circuit to positive".
Does this mean that the fuel pressure sensor could be faulty, or some possible wiring issue?
Can someone indicate to me where the fuel pressure sensor can be found?
Any other tips?
P.S. Tried searching the forum for P3628 but came up empty...
Old Mar 10, 2026 | 12:47 AM
roadtalontsi's Avatar
10 C six trizzle
The sensor is located at the front of the driver's side fuel rail. typically that code indicates either component isn't plugged in / wiring damage or the sensor is so far out of range it assumes it's not plugged in or shorted hence the code. I have seen injectors cause similar codes though if stuck wide open allowing fuel pressure to tank enough to make the ecu think it's a faulty sensor.
Old Mar 10, 2026 | 01:43 AM
DRBC43AMG's Avatar
Thanks for the reply.
I'll do a check to see if the sensor is plugged in correctly, or if I can see any wiring damage
Old Mar 10, 2026 | 01:25 PM
DRBC43AMG's Avatar
Rodent damage to the harness including a broken wire, probably due to a weasel. Now fixed and everything is back to normal
Rodent / weasel damage causing the P3628 error code
Old Mar 11, 2026 | 01:07 AM
10 C six trizzle
atleast its an easy fix. I hate those little ****s. do you need pn for new pins?
Old Mar 11, 2026 | 05:27 AM
DRBC43AMG's Avatar
Thanks for the offer. Got the repair done at the AMG dealer, and it was very reasonably priced. Nice for once!
