C63, C43 AMG (W206) 2023 -
Starter Battery Charge Level
Old Jun 20, 2024 | 08:00 PM
DYR's Avatar
DYR
'10 C300 4Matic, '24 C43 AMG
Has anyone else been getting "the state of charge of your vehicles starter battery is critical"? I'll drive around it's go away for a couple days but then return. I've gotten it probably 5 times in the last two weeks.
Old Jun 23, 2024 | 09:48 PM
AMPERAGE's Avatar
W206 C43
It's not uncommon. There has been talk about TSBs and an upcoming software update to rectify, but I'm not sure where MB is at with a fix.
Old Jun 23, 2024 | 10:05 PM
Iceclimber7's Avatar
SL55
Have your battery tested.
Old Jun 23, 2024 | 10:09 PM
AMPERAGE's Avatar
W206 C43
Dealership will likely say the battery passes their tests. The critical battery issue is due to the car getting an interrupted sleep cycle, which causes one of the pumps (I forget which, possibly coolant pump) to continue to run instead of shutting off after 15 minutes or so. The result is both the 48V mild hybrid battery and the 12V starter battery becoming depleted. You can see from the workshop menu that both batteries discharge when this happens.
Old Nov 17, 2024 | 08:01 PM
AMPERAGE's Avatar
W206 C43
An update on this issue for others. I've had numerous low/critical battery alarms over the past year, and asked my dealership to look at this issue (for the second time) during a recent vehicle service, and they appear to have fixed it.
The issue relates to the door control unit software remaining active, which keeps the vehicle from going into full sleep mode and runs the battery flat. Software has been updated on all 4 door control units, and my battery was also replaced as it failed a test (likely the battery was damaged due to being fully discharged multiple times in 12 months because of the software issue.)
The full notes for the issue from the dealership below:
Owner reported critical battery alarm keeps popping up.
Please check & report.
Internal battery fault and door control unit software issue.
Complaint confirmed, quick test, EZS fault code, (B1FCB97) tips #GI54.10-P-076868.
Battery test, failed.
R/R and replaced battery, updated all four door control unit software.
Cleared faults, function test after repair, in order, complaint rectified.
Old Dec 8, 2025 | 09:44 PM
gatormays's Avatar
Had the exact same problem. Root cause and resolution was identical as well. Provided this to technician and diagnosis/fix was quick. Thanks for posting!
