W206 C43 AMG Disaster
List of Service Visits and Issues:
August 30, 2023 (1 day) – Mercedes-Benz of Boerne, TX- Check engine light came on; stored faults for electric turbo.
- Transmission jerkiness – no issues found, transmission performing as designed.
- Engine engagement with ECO start jerky – could not duplicate issue.
- High beam assist malfunction – cleared codes.
- Knocking noise on engine start – no problem found, could not replicate.
- Digital headlights inoperable – no issue found.
- First A service performed.
- Left front door (driver’s side) would not open from the inside – repairs completed.
- Center command screen blurred, functions inaccessible – software update performed.
- Fingerprint authentication failed for primary driver profile – software update performed.
- Power steering squeal when hot – lubrication performed on steering rack.
- Transmission jerkiness from 1st to 2nd gear – adaptations performed.
- Open recall 202402005 for DRVU software update.
- Right window airbag malfunction – wire chafing, harness repaired.
- Harsh upshift and downshift from 1st to 2nd gear – no issues found.
- Thumping noise from telescoping steering wheel – play in column, performed column seat normalization.
- Same airbag issue as June 25, 2024 – insufficient fit at connector R12/23, connector replaced
- Starter battery malfunction (~20 plus occasions) which has been an ongoing problem since two weeks after the vehicle was purchased, DC/DC converter fault – several LI’s performed for diagnostics.
- Clunking noise from steering wheel vertical adjustment – vertical adjustment assembly replaced.
- Vehicle towed to dealer as a result of it not starting, collision alert displayed – no issues found.
- Rattling noise from driver's front door – seat switch/trim adjusted.
- Both front memory seat features and audible confirmation sound inoperable – speaker pin replaced.
- Loose rear vertical weather stripping – seal assembly replaced.
- Harsh transmission shutter and engine power loss in reverse – software issue identified, no ETA for new software.
- First B service performed.
- Driver rear door exterior trim piece not flush – trim replaced.
- A/C slow to cool – schrader valve replaced.
- Coolant level message displayed – no leaks found.
- Harsh upshift and downshift from 1st to 2nd gear and abruptly brakes.
- Received multiple malfunction messages and check engine light turned on.
- Both front memory seats are inoperable.
- 12V On-board electric system service required message.
