C43 BOV Adapter install
If you've got an adapter plate, it bolts directly to the compressor housing where the factory diverter valve sits. Tight spot, driver's side is easier.
Post a pic of what you found, I'll tell you if it's right.
It’s the solenoid off the intercooler with pipe going to top of the air box so I’m assuming it’s sending any excess air back into the top of the filter box
The boys at Burger Motorsport told me this is correct but I believed there’s supposed to be another similar valve on or near the turbo so was unsure which is the correct one that is if there is indeed another
This one seems correct
Appreciate your thoughts "]https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1124/img_1942_1d622e9f32a3bd9072d61ea9fe9d2b7bcf562292. jpeg[/img]
This is where I’ve installed the adapter It’s the solenoid off the intercooler with pipe going to top of the air box so I’m assuming it’s sending any excess air back into the top of the filter box The boys at Burger Motorsport told me this is correct but I believed there’s supposed to be another similar valve on or near the turbo so was unsure which is the correct one that is if there is indeed another This one seems correct Appreciate your thoughts
