C63/C63S AMG
Introducting W205 C63/C63S coilovers by Weistec engineering
Old Oct 6, 2015 | 04:28 PM
GMP Performance's Avatar
Former Vendor of MBWorld
W211 E500 Estate
Introducing Coilovers for W205 C63 and C63 S by our long term partner Weistec Engineering.
Order yours
HERE
Weistec Adjustable Suspension System for the W205 C63 and C63-S converts the front to adjustable coilovers and adds an adjustable perch for the rear. The system features CNC machined billet aluminum construction, anodized and laser engraved with part numbers and directions to simplify installation and adjustment. The adjustable perches feature ball spring set screws that allow you to "count the clicks" while adjusting ride height, making it easier to match side to side ride height adjustments.
The adjustable suspension system was designed to allow a wide range of adjustment in ride height, while still being able to maintain proper alignment without the need for special parts or tools. Perfected spring rates, chosen after thousands of miles both street and track testing, improve vehicle handling while height adjustments make for better fitment of aftermarket wheels and a more aggressive stance.
KEY FEATURES:
Bolt-On Installation
Simple Ride Height Adjustment
Ball Spring Set Screws
Engineered Spring Rates
CNC Machined and Laser Engraved Billet Aluminum
Stainless Steel Spanner Wrench
Hex Keys Included
Retains Factory Electronically Controlled Dampening System
- See more at: https://www.gmpperformance.com/index....NzybG2jl.dpuf
Old Oct 8, 2015 | 09:38 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Looks great, do you guys have any dealers in Sydney Australia?
Old Oct 9, 2015 | 10:03 AM
W211 E500 Estate
We are able to ship them to you if you would like!
I will send you a quote via PM!
Old Oct 12, 2015 | 01:03 AM
Sanch's Avatar
Great, look forward to it.
Also, how low is the car from the original height above? - looks perfect, exactly what I want. Cheers
Old Nov 25, 2015 | 01:07 AM
W211 E500 Estate
Roughly 1" to 1.5 lower
Old Dec 15, 2015 | 03:49 PM
W211 E500 Estate
Giving this great upgrade a bump! PM us with any questions.
