ED1 Wheel Weight
In case you are wondering what the wheel weight is for the ED1 wheels so you can compare with winter tire wheel weight (I'm that ****) the numbers are..
- ED1 Rear Wheel 19x9.5" alone - 26lbs
- ED1 Wheel with Michelin PSS - 48lbs
New Winter Wheels - Mandrus Rotec 19x9.5 w/ Nokian Hak 8 255/35 - 54lbs
One thing to keep in mind, the Michelin PSS is probably 70% worn and the Nokian Hak 8's probably have a pound or two worth of weight as a result of the steel studs...
Use a bathroom scale, so the weight could be out a bit... But the ED1 wheel in a box with a bunch of packaging around it weighed on the FedEx scale at 28lbs...
I also would have thought the ED1 wheel was a little lighter as it is forged.
Thanks for the info.
