C63/C63S AMG
Wider tires on stock wheels
Old 07-12-2016, 05:16 PM
SuperNik's Avatar
W205 C63S AMG
Probably around 3000 miles but to be fair it includes a track day at Donington and the rest of my summer miles have been spent in race mode with traction control off.
Old 07-13-2016, 09:16 AM
AMGTTV8's Avatar
AMG
I upgraded to 285 at the rear (michelin PSS) and the new found grip is ridiculous.
Wish I had put these on from the get-go.
0 issues whatsoever.
Cheers!
Old 07-13-2016, 01:13 PM
PunjabiM3's Avatar
R8 5.2 6MT
Cheers!
285-30/19?
Old 07-14-2016, 10:17 AM
AMGTTV8's Avatar
AMG
Originally Posted by PunjabiM3
285-30/19?
285/35 19
Old 07-15-2016, 04:24 AM
oreooreo3's Avatar
c63s
my original 245/265 so can i just go wider on the rear as 275 and keep the front the same as original size or the front have to be 255? Just curious!
Old 07-15-2016, 07:48 AM
CT-AMG's Avatar
AMG C63S
I don't know the answer to this definitively, but if you don't keep "20" between the front and rears then you will change the geometry of the steering design. Will it matter? I don't know. 245/65, 255/275, 265/285 (if possible).
To go 255/285 may be as large as we can go, but the car wasn't designed for the gap between front and rear.
Old 07-15-2016, 07:58 AM
  #32
SuperNik's Avatar
W205 C63S AMG
Does anybody know if 265's will fit on the fronts?
Old 07-15-2016, 10:47 AM
  #33
RDOCA's Avatar
2016 C63S Sedan
With stock wheels the tire rack chart says NO
Old 07-15-2016, 02:23 PM
  #34
msd3075's Avatar
'15 C63S
They very likely will fit on the wheels as in you'll be able to mount them. That doesn't mean that they will work any better (and in many cases won't work as well) than a skinnier tire.
Personally, the only tire size combo other than stock I would do on the stock 19" wheels would be 255/35-19 and 275/35-19. I'm sure you can go wider and not have any problems with outright functionality, but I don't think you are gaining anything going wider.
On a previous car I had tires that were wider than the recommended specs, and while I never had a blow-out/flat/rubbing/etc, you could definitely feel that the car was unsettled compared to the stock tire size. No point in having more grip if you can't predictably use it.
DZ8222 (07-21-2016)
Old 07-15-2016, 02:49 PM
  #35
RDOCA's Avatar
2016 C63S Sedan
+1
Old 07-21-2016, 10:55 AM
  #36
DZ8222's Avatar
C63S
Word
Anyone have photos of this set up?
Old 07-26-2016, 04:21 AM
  #37
Sanch's Avatar
AMG C63s
Cheers!
On the stock 19"?
Old 07-26-2016, 07:10 AM
  #38
theclutch's Avatar
C8, FF, C63S, 911 C4S, GTI, E350, Boxster S, 355, Esprit S4, Vantage, S5, Z4, M3, Miata, A4, 325is
Originally Posted by Sanch
On the stock 19"?
+1 and on what fronts? No rubbing on either front or back?
Quick Reply: Wider tires on stock wheels
