Rear bumper side fins
There are 4 parts in total - inner piece L & R, gloss black outer cover L & R
The inner pieces screw onto the bumper and then once secured the gloss black outer attaches using the 3M tape already applied.
The inner pieces have pre-drilled holes and in the kit are the screws and plastic 'rawl plug' type inserts - hold the inner piece in place on the bumper and mark the holes - it only fits in one place as it is shaped to fit into the moulded bumper perfectly.
Drill the holes, push in the inserts and screw the inner piece on tightly - once it is secured peel off the 3M tape from the gloss black outer and attach - it is best to trial fit these first before removing the tape as you only get one chance at getting them to fit and there is a little movement on fitment.
They literally take about 10 mins a side to fit
Once you have the kit in your hand, it will all be a bit more self explanatory
Open this link http://www.mercedes-amg.com/customiz...2=c63&lang=eng
Bumping this thread because I just ordered these.
If I'm understanding your intructions, holes actually need to be drilled into the bumper to install these? I was hoping to avoid that. Thanks.
Yes, they are designed to be drilled and screwed on - there is an inner plastic that is screwed in place, the thinner shaped outer piece sticks onto this with 3M tape - it might be possible to stick both parts on though I suppose?
I will just leave mine on the car when I eventually trade it in and being an official Mercedes AMG parts should have no negative effect
http://m.ebay.com/itm/Mercedes-Benz-...-/282391090727
Just curious about fit, finish, installation etc.
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=182601338032&cat egory=33638&pm=1&ds=0&t=1497871473567
I'm not even sure my screws are long enough.
I've test fitted these where they "snap" into the bumper, the top plate is flush, and there's still a gap in the back????
Please help!!!!
