C63/C63S AMG
Experience with additional ECU
Old Dec 22, 2015 | 12:18 PM
Vullnet Avdyli's Avatar
Mercedes C63 AMG S (W205)
Smile Experience with additional ECU
Hello C63 AMG Owners
I bought a Mercedes C63 AMG S and i think that de engine have more potential that the 510hp.
Do you know any additional ECU that brings more hp and ist compatible with Downpipes?
its also important if the car goes to Service, that they dont see the additional ECU in the car.
Do you know any Tuner who can do this?
thanks and greetings from Switzerland
Old Dec 22, 2015 | 03:32 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Yes these new turbo cars are under-rated from factory. Now I don't know what you mean by additional ECU?
ECU is a VIN coded part and cannot be used in another car than the one it has been coded for. Now you can buy a new or used ECU and get it programmed for your car with a tune. I only know Weistec as a vendor able to do so.
You can also buy a tune from a vendor offering a handheld device which will allow you to go back and forth between a tune and your OEM file.
Old Dec 23, 2015 | 12:40 PM
INS1GNIA's Avatar
'13 C63 AMG P31
It almost sounds like Vullnet wants to add an extra ECU to up the hp or to have another one for a tune while one remains stock. Sadly it does not work that way as abcut973 said.
Old Dec 23, 2015 | 07:32 PM
Mort's Avatar
Think the OP is asking about a piggy back controller and tune.
Old Dec 26, 2015 | 03:51 AM
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
Some other car brands use controllers. Even my genius is a kind of a "computer" that I think the op is referring to.
Old Dec 28, 2015 | 06:15 PM
i search something like the JB4 Tune for The BMW Turbo Engines.
somthing with more Maps that you can use. with JB4 you have map 0 = the car is like Stock.
with the other maps you can use more power from the tune.
additional you can take 30% Ethanol E85 (gives a lot of power)
and you can install Catless Downpipes without Enginge Check Failure. i think this is the perfekt tune for cars.
do you know a tune like this for Mercedes C63 AMG S?
