Wheel weights???
19" oem split 5 spoke weight? (front & rear)
19" oem cross spoke forged? (front & rear)
Then compare to something like 19" hre ff01 flow forms for example.
I think a 255/35 19 up front and 285/30/19 out back??? My cls550 had that setup and I liked it a lot. Save some weight, increase strength, and of course look good.
My E63 makes so much torque, that my forged monoblock wheels just kept spinning with my PSS. I switched back to low pressure cast, and gained my traction back... With PSS again.
If you run 285-30 in the back, this will help, however if you are hoping to run PSS, you'll have to settle for run flat as its the only option. If you don't lower your C63 too much, you'll be able to squeeze a 295-30-19 on there. (Depending on offset of your setup)
FF01's for the W205 in 19"x9" // 19"x9.5" weigh 25.4 pounds & 25.6 pounds respectively.
I reckon the P104 will look great - esp concave
Wheel Specs:
HRE FF15
19”x9” // 19”x9.5”
Finish: Tarmac
Tires: Michelin Pilot Super Sports
Front: 245/35/19
Rear: 265/35/19
Please PM us for details, availability, and pricing.
Tell us what you think by commenting below!
For more photos visit: https://www.flickr.com/gp/wheelsboutique/RpdR2F
