C63 Performance Tuning from Speedriven
Hi, guys! Posted this to our site's blog a few days ago- thought you might want to check it out here, as well.
Powered by an all-new 4.0 liter, twin-turbocharged V8 engine producing 469 horsepower, Mercedes-Benz’ latest C63 AMG model is a thoroughly modern sports sedan capable of supercar levels of performance. With 479 lb-ft of torque available 1750 and 4000 RPM, a top speed of 155 MPH, and the everyday drivability of a Mercedes-Benz, the W205-chassis C63 AMG is much more than a modern-day muscle car.
As good as the new-for-2015 C63s are, however, they could be better. Mercedes understood this, and released the 503 horsepower, 516 lb-ft version C63 S sedan … and that’s a good start, but Speedriven can make the C63 better, still.
Speedriven’s advanced ECU software upgrade boosts the C63’s output to some 580 HP and 670 TQ, with more than 600 lb-ft available between 3000 and 4750 rpm. In addition, the 155 MPH top speed governor is lifted, giving the C63 a potential top speed of 205 MPH (330 km/h).
C63 AMG ECU Software Upgrade | Dyno Graph
For experienced drivers who want to make the most out of their C63 on a track, Speedriven offers a set of high-flow performance downpipes that increase peak HP and TQ while also improving throttle response. They sound pretty impressive, too!
Speedriven also recommends a larger transmission pan for the C63. Machined from a single piece of aluminum, Speedriven’s billet trans. pan increases fluid capacity by nearly 2 liters, and offers superior heat transfer to help keep the transmission cooler in even the most extreme driving conditions.
In addition to our own, in-house products, we work with some of the most trusted names in the industry to provide your C63 AMG with competition-spec. brakes, suspension upgrades, lightweight wheels, and nearly everything else you need to build precisely the C63 you want here at our shop in Palatine, Illinois. Call or email us for more information, and check out our W205 C63 AMG product page for more pictures and pricing.
Questions:
Is the above graph to the tires?
Can you share stock vs. modded dyno results?
The graph was made to represent "crank" HP by adding 15% to the final wheel numbers. We didn't do a before, but if we have a customer who wants a before/after we can accommodate them.
