C63/C63S AMG
C63S Turbos not working
Old Jun 16, 2016 | 08:16 PM
wahoobo's Avatar
2016 AMG C63S Sedan
stock
Old Jun 23, 2016 | 05:00 PM
coold8's Avatar
2016 AMG GT-S
I'm having this happen on my GT-S as well.
Old Jun 25, 2016 | 04:25 PM
Oky's Avatar
Oky
2015 C63S Edition 1
At what temps is this happening to everyone? I only get this issue after driving hard on race and temps are about 220+. Never have had this issue while driving in comfort.
Old Jun 29, 2016 | 01:03 PM
jwalker's Avatar
w205 c63 s edition one
Turbos not working
Ive also had problems with my turbos not pushing any boost after I have ran it hard. I have about 12k miles on it now and have had problems with it sense about 7k miles. If anyone knows any solutions please share.
Old Jun 29, 2016 | 03:23 PM
PeterUbers's Avatar
Would be nice for the OP to come back and give some feedback after his trip to the dealer
Old Jun 29, 2016 | 03:53 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Something similar has been happening to my friends CLA. He will be driving and then the car looses all boost. He doesn't get any CEL's or any dash warning. He pulls over, shuts it off and restarts it and it's back to normal.
Old Jun 29, 2016 | 05:08 PM
  #32
RDOCA's Avatar
2016 C63S Sedan
I have had this problem also and am going in to the dealer next week or when they call that parts are here.
I am going in for the campaign on the elec. diff. plug and one other.
I asked him to check on the lost turbo boost and he texted me back saying he found it is a problem with a hose that gets kinked and he is also ordering that part.
That is all I know so far and will post after my visit as I will ask for details.
Old Jul 21, 2016 | 04:43 PM
  #33
RDOCA's Avatar
2016 C63S Sedan
As promised this is the work order from the dealer on the "NO turbo Boost problem"
A CUST STATES INTERMITTENTLY ENGINE HAS REDUCED/LOSS OF POWER (SOP IN
STOCK)
CAUSE: FOUND CODE P023409, VACUUM HOSE FOR WASTEGATE ACTUATOR FOR LEFT
TURBOCHARGER (09B01-A2 7)
540650 ON-BOARD POWER SUPPLY VOLTAGE MAINTAIN
(WHEN CHECKING/ TESTING AND TROUBLESHOOTING)
631 W08 (N/C)
541011 PERFORM QUICK TEST
631 W08 (N/C)
140000 PER LI, REMOVED VACUUM HOSE FOR WASTEGATE
ACTUATOR FOR LEFT TURBOCHARGER AND REPLACED
WITH NEW MOLDED VACUUM HOSE.
631 W08 (N/C)
1 177-142-06-00 VACUUM LINE (N/C)
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE A: 0.00
6022 PER LI07.09-P-063678, DC 09B01A27
54-0650[0.1]54-1011[.2]14-0000[0.1]zm. Performed short test. Found
fault code P023409 stored in engine control unit. LI07.09-P-063678 as
per LI removed vacuum hose for wastegate actuator for left turbochager
and replaced with new molded vacuum hose. Cleared fault codes after
repairs.
Old Aug 18, 2016 | 10:50 PM
  #34
coold8's Avatar
2016 AMG GT-S
Can you confirm if this worked for you?
STOCK)
631 W08 (N/C)
631 W08 (N/C)
631 W08 (N/C)
repairs.
Old Aug 18, 2016 | 10:56 PM
  #35
RDOCA's Avatar
2016 C63S Sedan
I can't say for sure yet as it has been intermittent but has not happened since they replaced the hose.
Old Aug 19, 2016 | 07:50 AM
  #36
CT-AMG's Avatar
AMG C63S
I haven't done anything to my car to remedy the issue and it hasn't happened to me again in 4 months or so. Very weird, intermittent problem that may not manifest itself again regardless of repair or not..
Old Aug 19, 2016 | 10:42 AM
  #37
RDOCA's Avatar
2016 C63S Sedan
Probably would not hurt to have them replace the problem hose when you are in for a service.
Old Aug 21, 2016 | 03:45 PM
  #38
YowzaC63's Avatar
2015 C63 AMG
Have any of you guys mentioned this in the Private Lounge? I am willing to bet they would be a good resource to helping resolve this issue. (just a suggestion)
Old Oct 13, 2016 | 09:38 PM
  #39
SAIVIII's Avatar
C63s Edition 1
can you tell me how to change engine data from kw to hp ?
Old Jan 11, 2018 | 12:46 PM
  #40
Ahmad Altaher's Avatar
c63 s
Did you fixed the problem?
Originally Posted by wahoobo
So this has been happening for about a month now, at the start it only happened once in a week but now it's once a day, the car works normally and everything functions as it should in the start but after 2-3 hours of driving the turbos produce no boost and I have to turn the car off and then on for them to work.
Anyone know what's happening here ?
Hello, Did you get the issue fixed? Im running into the same problem and any help would be great
Old Jan 11, 2018 | 06:55 PM
  #41
Dthquazi's Avatar
2017 c63s
Did you even read the thread?
