C63/C63S AMG
HELP !! WIDER TYRE WITH 12MM SPACER !!
Old Sep 5, 2016 | 07:51 AM
maxbeard4's Avatar
C63 s Edition 1
Hi,
I am in the process of arranging new tyres for my C63 S Sedan. I have 12mm HR spacers on there with extended bolts of course. Will i still be ok running 255/35/19 on my fronts with the 12mm spacers? or will it rub?
I am also going to be switching my rears to 275/35/19 because i understand you should keep the ratio the same between the front and the back, but they have a little life left in them for now.
Cheers
Old Sep 5, 2016 | 07:36 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Have you lowered the car? - do you have pictures?
If the cars been lowered might be an issue.
Old Sep 6, 2016 | 05:56 AM
maxbeard4's Avatar
C63 s Edition 1
No the car has not been lowered, just the spacers have been applied.
Pictures below
Old Sep 6, 2016 | 09:26 PM
e920610's Avatar
w205c63s
Did you use 12mm spacers all around the corners?
did you notice any rub under full lock or going over the bumps?
Im trying to find out aggressive offsets without looking like 4x4
Old Sep 7, 2016 | 03:31 AM
maxbeard4's Avatar
C63 s Edition 1
I used 15mm at the rear and 12mm at the front. No rubbing at all. went for the 245/35/19 at the front just in case they rubbed with the 255.
