C63/C63S AMG
C63s Coupe - Obsidian Black
Old Nov 2, 2016 | 09:13 PM
  #276
auditoamg's Avatar
C63s
Originally Posted by Sanch
I have 15mm ECS in the front fits perfectly flush... you won't have any issues.
Is your offset on the aftermarket wheel the same as the OEM 19????
Old Nov 2, 2016 | 09:18 PM
  #277
auditoamg's Avatar
C63s
Air suspension in an AMG?
Unless its a G wagon, it doesnt make sense.
On my build sheet it's
488 AMG Ride Control Sport Suspension
Old Nov 2, 2016 | 09:38 PM
  #278
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
I've still got the OEM wheels... most likely get wheels down the track!
  #279
Sanch's Avatar
That sounds correct...
Old Nov 2, 2016 | 09:55 PM
  #280
auditoamg's Avatar
C63s
Dude... You rock.
Did you get wider tires in front, as well?
Per the other thread, 265s in front???
Old Nov 2, 2016 | 10:51 PM
  #281
Sanch's Avatar
Dude... You rock.
Not yet, I'm waiting for it to wear out. If I stick to the stock wheels I'm planning to go 265 fronts and 295 rears.
However, I'm keen on getting new wheels... so once I find something I'll switch to that.
Old Nov 2, 2016 | 10:58 PM
  #282
auditoamg's Avatar
C63s
If you stick to stock, are you keeping the spacers in front and why aren't you going 305s in back? I thought we could go that wide in back... Just checking as you have thru defacto coolest ride...
Old Nov 2, 2016 | 11:04 PM
  #283
Sanch's Avatar
Yes will keep the spacers... it will only be a minor difference changing 255 to 265.
305/30/20 will give the side walls the balloon look - which I don't like at all.
I like the look now and 295s wont change that too much.
My Shop advised to have a similar look as now I would have to go 305/25/20.
In saying that, lets see how we go when I need to change the rubber.
Old Nov 2, 2016 | 11:11 PM
  #284
auditoamg's Avatar
C63s
I'm not a tire expert.... I'm ordering tires now. If you go down to the 305/25, doesn't that take the sidewall down and make it more dangerous for the rim?
Old Nov 2, 2016 | 11:13 PM
  #285
Sanch's Avatar
Exactly, I rather stick to 30 series rubber than go down to 25s.
Order the 305/30/20... you can test it out for all of us :P
Old Nov 2, 2016 | 11:22 PM
  #286
auditoamg's Avatar
C63s
LOL....
Old Nov 2, 2016 | 11:27 PM
  #287
Sanch's Avatar
LOL....
Just FYI - PSS tires come in MO (Mercedes original) written on the tire.
I planning to use the GTS tires which is also MO - the GTS size is 265 & 295 which works perfectly for our car.
Old Nov 3, 2016 | 05:10 AM
  #288
DragonRR's Avatar
911 991 TTS, Audi RS6 C7 Performance Edition, AMG GTS
Originally Posted by alexasa
I've tried a few different spacers.
I haven't had any luck with hub centric spacers fitting.
H&R's did not fit and ECS did not fit.
Now I am using 8mm with no hub centricity (using OE hub to mount).
If I'm interpreting this correctly the 8mm spacers allows the original hub to poke through the hole in the spacer enough to locate the wheel in position. I personally wouldn't go for this because (imo) it doesn't leave enough of the hub to take the stresses but it does mean the lugs aren't doing all the work!
Sanch - your 15mm spacers work (AFAIK) because the inner flange which carries the extended "spacer hub" is just beyond the end of the existing hub. As you may remember from our conversations you thought that 15mm might be too thick for the oem suspension and the shop agreed when I first visited to decide which spacers to go for.
For clarity I knocked this up... not to scale! This is/was my problem (exaggerated) with the thinner spacers
Old Nov 3, 2016 | 08:03 AM
  #289
alexasa's Avatar
c
exactly. It's not something I'd take to the track, but it has given me no issues.
I tried 10 and 12.5 mm spacers and both did not have the appropriate chamfer.
I have never had issues fitting spacers on a car before, have ran DRA/DR style multiple times in all sorts of thicknesses.
(15mm is more aggressive than I want on my 450 - 5 up front and 12 out back would be right on the money)
Old Nov 3, 2016 | 09:10 AM
  #290
auditoamg's Avatar
C63s
Are you running a spacer in the rear, too?
Old Nov 3, 2016 | 02:28 PM
  #291
Uga Uga's Avatar
2021 C63S coupe
Here's a copy of the order form
Old Nov 3, 2016 | 05:27 PM
  #292
auditoamg's Avatar
C63s
Weirdest thing...
You are in the UK, someone else in the UK wanna post their order form?
Old Nov 3, 2016 | 06:55 PM
  #293
Uga Uga's Avatar
2021 C63S coupe
This is the factory ordering system printout.
Normally handled by the admin guys at the dealership.
Old Nov 3, 2016 | 07:48 PM
  #294
Sanch's Avatar
Sure am... 12mm in the rear.
Which might need to go to a 8mm when I go 295s.
Old Nov 6, 2016 | 07:49 PM
  #295
Sanch's Avatar
Not the best shot, but had someone send this to me... looks good in motion!
Old Nov 7, 2016 | 01:18 AM
  #296
SBH-'s Avatar
C63S 2016
looks verrrry good in motion! I'm getting jealous now ..
Old Nov 23, 2016 | 01:39 AM
  #297
303_AMG's Avatar
2017 C43. 2006 Ford GT. 2017 Wrangler. 2010 S4
Here it is!
Looks unbelievable in real life...
It's off tomorrow for front clear wrap, tints and Modesta coating!
May I ask how the white interior has held up over time? Very close to ordering the white/black designo interior on the C43 I'm about to get, but am weary of whether the white will stain easily and/or be hard to maintain.
Old Nov 23, 2016 | 01:45 AM
  #298
SBH-'s Avatar
C63S 2016
tbh, ive had the white interior for nearly a year and its still perfect.
Old Nov 23, 2016 | 01:49 AM
  #299
303_AMG's Avatar
That's definitely good to hear, thank you for the reply, I'll be keeping this car long-term (purchasing not leasing) so it's a concern of mine. I know the black leather with red accents or brown designo will be less inclined to stain, but the black/white looks so good (especially with a black exterior).
Old Nov 23, 2016 | 02:28 AM
  #300
SBH-'s Avatar
C63S 2016
listen, if you coat the interior (atleast the white parts of the seat, it would certainly be plus for you).
