C63/C63S AMG
Entry/exit function-2017 C63s coupe
Old Nov 3, 2016 | 03:24 PM
Gunsmd's Avatar
2017 Mercedes C63s coupe
Cool Entry/exit function-2017 C63s coupe
Have the AMG seats with the P3 option package. Entry/exit is turned on in the Command system. Seat and steering wheel due not move upon exiting with door open or getting in and closing door. Anyone know what's up?
Old Nov 6, 2016 | 06:14 AM
SBH-'s Avatar
C63S 2016
I know that the seat does not move in my sedan. however, you might already have the steering wheel set to the position of the easy entry/exit ? I mean when I open the door the wheel goes up to a certain position, and you might already have it set at that height ?
Old Nov 8, 2016 | 04:11 AM
Gunsmd's Avatar
My wheel is not set high up so it should move up when I open the door but it doesn't
Old Nov 8, 2016 | 04:27 AM
SBH-'s Avatar
C63S 2016
well that's unusual ....
Old Nov 8, 2016 | 10:17 AM
RDOCA's Avatar
2016 C63S Sedan
Try moving the wheel down more when in car and running.(just so you can see more movement.)
Then shut off and when you open the door it should go up and when you come back and start it will come down.
Mine does .
Old Nov 8, 2016 | 12:09 PM
DragonRR's Avatar
911 991 TTS, Audi RS6 C7 Performance Edition, AMG GTS
Mine does .
Yes I tried mine today and it seems to work normally too. Have you added your driving position to the vehicle's memory? If not, try adding it to all 3? 2? settings and trying it again.
Old Nov 8, 2016 | 05:34 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Mine works fine.... have you saved your setting in the memory?
Old Sep 24, 2019 | 08:55 PM
Stan_MBZ's Avatar
A220 AMG-line
I am in the US. No elect steering wheel adjusters...but my seat does pull forward whenever I stop the engine and open the door. I’m 6ft and it does help get me closer to the door for easy exit.
