C63/C63S AMG
C63s coupe - diff issues
Old Jan 2, 2017 | 09:01 AM
Momanc's Avatar
C63 coupe
Has anyone else had this problem? I've taken the car to my dealer multiple times and they don't know how to fix this and they won't replace the diff. I keep hearing clunking/knocking noises whenever I turn. It's the fourth time it's came up and all four times the dealer couldn't help me!!
Old Jan 2, 2017 | 09:03 AM
juse's Avatar
c63 coupe
Old Jan 2, 2017 | 10:19 AM
Geno40's Avatar
2016 C63 S
I had this issue recently, went to a dealer and they fixed by reconnecting and securing some wire. No more so far .
Old Jan 2, 2017 | 11:07 AM
RDOCA's Avatar
2016 C63S Sedan
there is a Campaign on some cars on this
Old Jan 2, 2017 | 11:59 AM
303_AMG's Avatar
2017 C43. 2006 Ford GT. 2017 Wrangler. 2010 S4
Clunking/Knocking noises when you turn can often mean something to do with the suspension. I had something similar happen in my S4 and it turned out they hadn't tightened down some part of the suspension when they put it back together after swapping some parts, just a thought.
Old Jan 2, 2017 | 03:14 PM
Dthquazi's Avatar
2017 c63s
Try a different dealer if you can. I would not drive it if you can in the mean time. I don't know what country you are from but I would attempt to contact Mb directly if you are getting no help from dealers.
Old Jan 2, 2017 | 05:40 PM
msd3075's Avatar
'15 C63S
There was a TSB out on certain early C63S that had to do with a plug that need to be added/secured that was allowing water to get into wherever it didn't need to be.
Don't think this applies to you though since it was on sedans built before the coupe had been available, and the quick VIN search done by the dealer should have brought this up if it were the issue.
Old Jan 2, 2017 | 09:55 PM
Momanc's Avatar
C63 coupe
MB did pull apart my diff the first time I had this issue and they told me they noticed that the pics weren't linked correct or needed to be realigned, I'm not too familiar with all the technical terms but whatever they did didn't work. They had my car for over two weeks the last time and again hopeless.
I don't drive the car hard or do anything stupid in it, not sure why this keeps happening.
Also my exhaust rattle really loud between 2-3000rpm, it's from the internal valves but again MB told me there is no solution to fix this and they won't replace the exhaust as the new one will end up with the same issues. I'm starting to get the day I bought this car!
Old Jan 3, 2017 | 04:40 AM
Uga Uga's Avatar
2021 C63S coupe
Originally Posted by Dthquazi
Try a different dealer if you can. I would not drive it if you can in the mean time. I don't know what country you are from but I would attempt to wcontact Mb directly if you are getting no help from dealers.
The above post is the way to go.
Old Jan 3, 2017 | 11:17 AM
RDOCA's Avatar
2016 C63S Sedan
+1
Old Mar 17, 2017 | 06:41 AM
Denis Najzar's Avatar
C63 AMG
Hi,
I have the same issue Elctronic rear axle differential lock inoperative. The MB cant find in the system that the 3000kms service was done so therefore they are trying to charge me to get this fixed.
When did you start getting this error? I have 26,000kms?
