It's an s205 but I think they're the same fitment as a w205I'm running 20x9 fronts and 20x10 rears. 255/30 fronts and 285/30 rears. 9.5 fronts is definitely a possibility. My rears are just about perfect
Running 10J ET45 with 265 40 18 hankook rs4. Stock camber arm, no rubbing.
What are you specs for front and rear? Looking to get new rims and want to know if 9 in the front and 10 in the rear would be fine. Not sure what size tire for the front but would 285 on the rear cause any issues for stock suspension?
The set in this pic is 9J ET25 10J ET45 with 245 40 18 and 265 40 18 semi slick. No rubbing.
If you wanna run 285 on 10J, probably need to push ET on the rear to 50ish+.
HRE 19" FF04's (F:19x9 35 offset R:19x9.5 45offset) 255/35-275/35 ordered them from WheelsBoutique advertising here on the forum. great customer service! I highly recommend.
Hey mate!! Love the way this looks!!
When you say OEM double-staggered could you elaborate on exactly how you got to this gorgeous end result!?
Thanks!
Here’s my ride currently, basically stock. But, with some spacers for the time being. I was playing around with some spare yellow vinyl. Ended up taking it off. What’s everyone’s thoughts? Stock ride height, with 20mm spacers up front & 17.5mm in the rear - from CTS.
