C63/C63S AMG
C63s Tire Lifetime
Old 04-02-2017, 02:53 AM
SBH-'s Avatar
C63S 2016
C63s Tire Lifetime
Hi guys,
I just wanted to have an idea of the tread wear of your tires, and how long were you able to run on a set of tires. Luckily, that day I parked my car with the steering fully turned to the left. when I came back, I was shocked to see the wear of the front left tire, the canvas was showing! I quickly turned to check the front right tire, and it wasn't as bad, but it was evident that the tire started to wear out.
Bear in mind that my current mileage is approx. 41,000 Km and I've got the Michelin PSS. Is that considered to be a normal lifetime for these tires?
Old 04-02-2017, 04:10 AM
RDO247's Avatar
C63S
Originally Posted by SBH-
Hi guys,
My fronts were done at about 15000km.
Worn on on the inside and on the outside, pictures shown in my other post.
Bad alignment from factory I think.
Old 04-02-2017, 04:16 AM
SBH-'s Avatar
C63S 2016
I have the same problem... yeah maybe that's the case. Anyway, would it be safe to bring front the 265s (rear) and get new rears?
Old 04-02-2017, 05:27 AM
RDO247's Avatar
C63S
thats exactly what I did.
Search through my posts for the information if your interested.
Old 04-02-2017, 09:32 AM
shoe3k's Avatar
nothing
The stockers for a sedan are:
Fronts: 19x8.5 (235R35)
Rears: 19x9.5 (255R30)
You could safely and comfortably put 255 on the front and 275 in the rear. I know people have been putting on wider tires for the fronts/rears but that is really not recommended even if the tire doesn't rub.
Old 04-02-2017, 10:02 AM
RDOCA's Avatar
2016 C63S Sedan
Fronts: 19x8.0 (235R35)
Rears: 19x9.0 (255R30)
Your recommendation is correct but the stock tires and rims are wrong.
19x8.5 f--245/35/19
19x9.5 r--265/35/19
shoe3k (04-02-2017)
Old 04-02-2017, 03:47 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
Just did 4 tires all around - 4000 miles - purchased the car in November of last year. The front tires were literally shredding and the rear tires were bald - terrible alignment from the factory as well
Old 04-02-2017, 05:06 PM
BD-C63's Avatar
2015 C63S AMG
It will be a short but memorable lifetime for these tires!
Old 04-02-2017, 05:55 PM
jkob5's Avatar
19 E63s
Wow that is brutal. I've got 4k miles on mine, also purchased in November, and the tires have very little wear. Track days? Always aggressive driving?
Old 04-02-2017, 06:01 PM
RDO247's Avatar
C63S
For me, daily driving, no tracking...
I would recommend getting an independent wheel alignment once taking delivery of new W205 C63's to increase tyre life.
Old 04-02-2017, 07:18 PM
AMG 17GT's Avatar
R Nine T
Why would you not get dealer to check camber?
Old 04-02-2017, 07:36 PM
RDO247's Avatar
C63S
Well, wheel alignments are part of the pre-delivery process when getting the car ready for the customer.
Which means the Mercedes Service Centre should have wheel aligned your car before you picked it up.
If the car is being handed over to the customer and within 15000km are wearing unevenly due to factory toe and camber settings nothing will change when having service centre check the alignment.
I complained to my service centre that my cars steering felt funny when going around round abouts and it felt as if the front wheel was digging in.
They asured me that the alignment was done and disregarding my claim.
Its up to you what you do but from my and experience an independent alignment at the start may prolong the life of your tyres.
Below are my fronts at 15000km of daily driving.
This wear is caused by incorrect toe.
Left tyre here is back to front, however, you can see left side is worn more the the right, the outside edge is bald and the inside is worn to canvas.
Old 04-02-2017, 07:41 PM
AMG 17GT's Avatar
R Nine T
I get what your saying.
Have the dealer give you factory spec first and go from there. If tire wear is uneven from that point then they owe you 700$ worth of tires.
Make sense??
Old 04-03-2017, 02:11 AM
SBH-'s Avatar
C63S 2016
so I should be grateful that my front tires gave me 41000 km
Old 04-03-2017, 11:13 AM
vaelin's Avatar
'15 C63S
20k miles.
Old 05-07-2017, 06:19 PM
ManveerS's Avatar
2016 c63
I have the 18 inch wheels. Could I fit 255 and 275 on those?
Old 05-08-2017, 07:59 PM
milan25's Avatar
C63 s Edition 1 Sedan
I got 10k out of my PSS and the entire inside was worn down to the white thread.
Old 05-10-2017, 11:22 AM
Make sense??
Unfortunately, they don't. My factory alignment was terrible and tires wore out around 3500 miles. Reaching out to MBUSA was fruitless, even though my alignment shop pointed out flaws in the alignment that were "extreme," in his opinion.
Old 05-10-2017, 11:52 AM
msd3075's Avatar
'15 C63S
I got about 13K out of my stock rear set of Dunlop tires. The fronts had maybe 25-30% of life left in them.
I switched to Michelin PSS tires at 13K, and am now at 23K miles. Have maybe 20-25% of life left in the rears, and when the rears are worn I have a feeling the edges of the fronts will be worn as well.
All in all, without the alignment issues described by others above, expect between 12K and 20K miles out of a set of tires depending on your driving habits.
Old 05-11-2017, 07:07 AM
Matty779blue's Avatar
C63s
Biggest tyre for rears
Gents
Given you are talking tyres I hope you don't mind me asking a question.
The Michelins on my rears are in need of replacement after 10,000 miles. I am reasonably happy with this as they haven't had the easiest of life. However I have been reading various forums about tyre size options.
There seems to be differences in opinion and it doesn't help that different countries seem to have different tyre options as standard.
I have the 19" multi spoke black wheels which I believe are 19x9.5
They came with Mitchelin 265/35's
I want to go as wide as possible and I have seen some people state they have fitted 285/30's with no problem, others state 275/35's. Which one is right?
Further (this probably shows how little I know about the mechanics of a car) with bigger tyres does this affect the alignment settings or will the garage still be working off the MB standard alignment?
Any advice greatly appreciated.
Regards
Matt
Old 05-11-2017, 09:35 AM
msd3075's Avatar
'15 C63S
Originally Posted by Matty779blue
Gents
Regards
Matt
To get extremely technical, going to a wider tire on an existing wheel size with the same alignment specs will change how optimized those alignment specs are, but it'd be so minimal with that small of an increase in tire width that I doubt you'd even notice a difference.
And you can fit 285's on the stock rear wheels, but you run into issues being able to mount comparably sized front tires on the stock front wheels. Without going into a long-winded explanation that has been posted on here numerous times, if I were you I wouldn't go any wider than 255/35 and 275/35 on the stock wheels.
Old 05-11-2017, 10:13 AM
C63s
Mate you are a legend thank you.
That is just what I needed to know
Old 05-11-2017, 03:37 PM
RDOCA's Avatar
2016 C63S Sedan
+1
Old 05-12-2017, 12:01 AM
SPONSOR
K-Mac's Avatar
Mercedes-Benz CLK 550
Do point out that OEM there is only ‘Toe’ adjustment front (and rear)!
OK if vehicle maintained and driven at showroom height, but day to day commuting encountering high cambered roads, altering/lowering height, load carrying, suspension sag, fitting wide profile tires or curb knock damage – the feature of having front and rear “ongoing Camber adjustment” to change tire “contact angle” is essential along with capability for extra Camber to reduce understeer/increase track width on Race days. With front Caster to “correctly resolve” steering pull and improve brake and steering response.
We saw the need therefore to design, manufacture and reinstate from the early ‘90’s kits that provide precise adjustment (on car under load direct on alignment rack). Also replacing the 4 front and 4 rear highest wearing suspension bushings at the same time. Result is no more ongoing trips to dealers or alignment shops or constantly changing tire brands. Fixing it right…. the 1st time!
For the front (only) you can purchase fluted bolts (not C63/S, S63/S65) – but they are inaccurate having ONE ONLY OFFSET POSITION, providing 3mm (1/8”) which is a minimal 0.3 degree change. The K-MAC patented design allows up to 3 times the adjustment range and is “precise accurate single wrench” adjustable.
Rear kits also provide Camber (and additional rear Toe adjustment to compensate for the new Camber facility). We do not manufacture rear Camber arms – as difficult to fit, access and adjust. Also to resolve premature inner edge tire wear need to reduce all important clearance top of tire to outer fender. Instead the K-MAC unique patented design precise single wrench adjustment system replaces the “lower arm inner bushes” moving base of tire inwards (or outwards to increase negative camber/track width). Comes with bush extraction tool allowing the Camber bushes to be installed on vehicle.
The front bushings are 2 axis/self aligning but without the oil and air voids of OEM. Result is noticeably improved brake and steering response. No modifications to fit – come with instructions and extraction/insertion tubes.
Also manufactured for the rear suspension is a full set of 12 replacement bushings for the 6 multi link arms. Providing significant improvement to rear end stability. Less flex/twitch, increased traction especially when applying power lane changing/overtaking.
W205
Front Camber and Caster
C400/C450/C43/S63 AMG 4matic #503216K $480
C63/S,S63/S65 AMG #503316K $480
Rear Camber (and extra Toe) #502226K $480
Rear multilink arms performance bush kit #502628K $480
Delivery $30 one kit or $50 front and rear (average delivery time is 3 to 4 days). We accept Visa, MasterCard or PayPal.
C63s Tire Lifetime-502016-cover.jpg C63s Tire Lifetime-502226-cover.jpg C63s Tire Lifetime-501526-2-j-cover.jpg
Old 05-12-2017, 01:34 PM
vaelin's Avatar
'15 C63S
I'm not sure if that was even English.
Quick Reply: C63s Tire Lifetime
