C63/C63S AMG
Driver side power folding mirror failed
Old May 15, 2017 | 08:53 PM
ruey220's Avatar
ml55, Ml63, Porsche, C63S ED1
I had the setting setup to fold when I locked the doors, and over the weekend the driver's side no longer will open back up to driving position. So I had to push it out manually because no matter what I couldn't get it to fold back open either manually pressing the button or locking and unlocking the door multiple times to get it to open per the setting.
I expected to get these quirky defects as always is the case with newer cars with so much technology, but then again I didn't expect it to be something so simple to break! Warranty time
Old May 16, 2017 | 09:41 AM
shoe3k's Avatar
nothing
Are there any noises from the mirror when you did your testing? If not, the mechanical pieces are probably OK in the mirror and might be due to software or just power to the housing. Are the LEDs on the mirrors working?
Old May 16, 2017 | 10:38 AM
ruey220's Avatar
yes no sound from motor, just completely dead. the LED is working. I thought about software also, but then again even the manual fold button on the driver's side door doesn't cause it to open and close, but the other mirror works just fine.
Maybe a fuse had popped specifically for the motor but then again I doubt MB would separate a fuse for each side just for that specific purpose of folding mirrors?
