C63/C63S AMG
Launching on a prepped track (sub 2.0 60')
Old Jun 14, 2017 | 11:22 AM
MattyMacro's Avatar
2017 C63S AMG Coupe
Heading up to Bandimere this afternoon to get a few runs in. I'm wanting 100 stock vs piggyback tune (via MPH difference). Obviously, I would like to get the best ET as well. Now my question for those that have gotten sub 2 second 60's.... How are you launching?
1. Are you using race start, brake-torque, or just going full throttle off the line.
2. ESP in race or completely off?
3. Auto shift or manual? (I think I will run auto for the sake of consistency since the MPH difference is my #1 goal this evening)
I plan on running the car in Race mode, auto and will be on 100 octane with 295 RE-71R's for tires. Will be doing a pull without the tune, on map 4 and then another on either map 8 or 9 as well.
Hoping to crack an 11, but that may be a bit too optomistic since we are in Denver and the DA is already 6240 ft. and will be 8000ft+ this afternoon.
Old Jun 14, 2017 | 11:59 AM
AlexZTuned's Avatar
2017 Porsche 911 C4
The best I've managed stock is a 1.978 60' ft (11.6@121.74).
Race mode:
- Suspension on hardest setting
- Auto shifting
- ESP Sport On
I dropped my rear tire pressure to 32 psi (stock PSS's) and used Race start.
I've heard that some have had success with brake boosting instead of Race start, but I haven't tested it out. Curious to see other peoples launch techniques
Good luck!
Old Jun 15, 2017 | 11:15 PM
Unicorn_'s Avatar
AMG C63S
Would a launch not be more effective if the suspension is in Comfort mode, allowing the back of the car to squat over the slightly deflated rears a little more to help get the power down?
Old Jun 16, 2017 | 12:46 PM
tscales's Avatar
2005 E55 Wagon, 2017 C63S Cab, 1986 560SL
My best is 11.943.
Very simple.
Race mode
Launch control
That's it.
Old Jun 16, 2017 | 02:11 PM
Mikey_boy's Avatar
2017 C63s Sedan | 2016 Yukon XL Denali
I have a picture of a 1.907 60' time. This was a 11.701 1/4 mile run. I managed a 11.68 as well, but no picture.
Stock tires, engine, etc.
Full tire pressure
1/2ish tank of gas
What I did:
Car in Race mode
Traction control all the way off
Get a little water on rear tires
Small burn out to warm tires (fun to watch with the 360 camera)
Pull up to line and engage race start
At first yellow light, gas pedal down
Third yellow light, brake pedal up
This way, I'm actually still pressing down on the gas as I launch and I had excellent grip
Keep pedal to floor until the end....
Oh, and this run was my FIRST EVER 1/4 mile run in this car. I was very impressed.
Old Jun 16, 2017 | 03:33 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
I thought the same and actually tried it several times in Comfort suspension and got horrible wheel hop, ended up running mid-12's because of it. The stiffest suspension setting worked best for me on this particular surface, it launched perfectly.
Old Jun 20, 2017 | 11:54 AM
MattyMacro's Avatar
2017 C63S AMG Coupe
Ok, tried a few methods here. I was on a RE71R tire (295) @ 40psi
Mode: Race
ESP: Race
Race start: yes
Managed a couple 2.2-2.4 60' Car would actually bog. Not sure if track prep was on fire, these tires are just too sticky, or a combination of both.....
Mode: Race
ESP: Completely off
Race start: yes
Same as before. 2.2-2.4 60' Too much traction.
Mode: Race
ESP: Off
Race start: No, brake-torque off the line.
2.4 60' Car immediatly spun hard in 1st as soon as I came off the brake. Need more tire to launch using this method.
Sooo, looks like I still need to figure out how to get a good 60' up here.
Old Jun 20, 2017 | 02:29 PM
Guilty's Avatar
'16 C63-S
Mode: Race
ESP: Race
Race start: yes
Mode: Race
ESP: Completely off
Race start: yes
Mode: Race
ESP: Off
40psi? Seriously?
Old Jun 20, 2017 | 03:04 PM
tscales's Avatar
I drop psi to 25.
Guilty's Avatar
'16 C63-S
32psi, Esp Sport, Automatic, Race Mode, Suspension in Comfort. Just easing into it. PSS.
Stock tune with upgraded turbos. March 26 '17
Old Jun 20, 2017 | 03:53 PM
AMG 17GT's Avatar
R Nine T
Great time sir. Thought your trap would be higher.
Old Jun 20, 2017 | 03:54 PM
Guilty's Avatar
'16 C63-S
That was on a stock tune! Back in March. We didn't have time to tune the car properly. So I went anyway to get a baseline. Haven't been since.
I'm actually getting a proper dyno tune tomorrow. Can't wait.
Old Jun 20, 2017 | 04:19 PM
AMG 17GT's Avatar
R Nine T
I'll be tuned in
Old Jun 20, 2017 | 06:09 PM
MattyMacro's Avatar
2017 C63S AMG Coupe
Originally Posted by Guilty
40psi? Seriously?
Yes, seriously. No point in dropping pressure if the tires were already grabbing hard enough to bog using launch control.
Old Jun 20, 2017 | 06:11 PM
Guilty's Avatar
'16 C63-S
Yeah.. I can see that it's working
Old Jun 20, 2017 | 06:15 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
You really do need to drop the tire pressure. 40 psi is crazy high if you're trying to get a good hole shot. Definitely go back and try again at 32psi or lower, and play with the suspension stiffness as that effects the launch as well.
Old Jun 21, 2017 | 11:07 AM
MattyMacro's Avatar
2017 C63S AMG Coupe
Gentleman.... The issue isn't lack of traction.... I have too much which is causing a bog... Generally, lower tire pressure = more contact patch and less stiffness in the sidewall. I need some spin to carry me through the bog, hence why I didn't drop pressure.
Old Jun 21, 2017 | 11:22 AM
RDOCA's Avatar
2016 C63S Sedan
Sounds like when the race start not used you spin way too much so you need to lower pressure.
In race start I don't think it is bogging but the race start computer is controlling the wheel spin.
Old Jun 21, 2017 | 11:23 AM
AlexZTuned's Avatar
2017 Porsche 911 C4
You just said in your last run you had ESP off and you spun hard with just brake torquing... why start a thread asking for launch advice and then shoot down all suggestions.
Clearly you know better than us, keep it at 40 psi and good luck for next time
Old Jun 21, 2017 | 11:49 AM
msd3075's Avatar
'15 C63S
I think you are missing what they are saying. The runs you did with launch control didn't bog because of too much traction but instead that the ESP (even though it's off) is working with the launch control and preventing the wheel spin. You don't have an excess amount of grip; you have an excess amount of ESP intervention. And this is more than likely caused by tire pressures that are too high, causing lack of traction, with an end results of ESP intervening and making it feel like the car is bogging down.
The simple fact that you could significantly break traction from a non-launch control start means you do not have too much traction. If anything, that would be the launch method that should be the hardest to cause excessive wheel spin. You'd think dumping the clutch at 3K-4K RPM like launch control does would be way, way more likely to prevent any sort of bogging.
Old Jun 21, 2017 | 12:02 PM
MattyMacro's Avatar
2017 C63S AMG Coupe
When I ran with ESP completely off, it still did not spin. It would bite hard and bog down. It needs more RPM or more positive vacuum coming off the line, not more traction.
The brake torque method causes positive vacuum where LC doesn't. This would result in more torque, much sooner than just using LC, which would result in wheel spin. Lowering pressure in the tires wouldn't have salvaged the run.
I'm not saying I do or don't, however, this isn't my first rodeo on a track. Prior to this I had a low 9 second GT-R that saw regular track duty.
I understand what's being said. You're stating that even with ESP off, it still regulates traction when using LC? I was under the impression that with ESP defeated, it completely eliminates traction intervention, with and without LC being used. I've lit my tires up pretty hard a few times with it completely off.
Old Jun 21, 2017 | 12:13 PM
msd3075's Avatar
'15 C63S
The only time you ran with ESP completely off was with the non-launch control start. At least based on my understanding of launch control, ESP is still active to modulate wheel spin. It's not just a "dump the clutch" feature.
On a side note, as was taught to me (and probably many others) at the AMG Driving Academy, cars equipped with the MCT transmission (wet clutch instead of torque converter) cannot be brake torqued like a normal automatic transmission. There is nothing to build up like what you would with a torque converter. All you are doing is forcing the clutch to try to grab, and it doesn't want to and thus won't let you. This was explained to us by both the driving instructor and the "ask this guy any technical question" person.
As I said above, my understanding is that with launch control enabled you are still going to see intervention from ESP in that it will still attempt to control wheel spin. After all, isn't that the point of a launch control system?
Old Jun 21, 2017 | 02:37 PM
RDOCA's Avatar
2016 C63S Sedan
"As I said above, my understanding is that with launch control enabled you are still going to see intervention from ESP in that it will still attempt to control wheel spin. After all, isn't that the point of a launch control system?"
+1
