C63/C63S AMG
E-brake functionality
Old Jun 20, 2017 | 12:40 AM
auditoamg's Avatar
C63s
So...
I've had two E and c loaners and we just bought a new 2017 GLC.
All of them remove the e-brake upon shift to drive....
My C63s removes it when I apply a little throttle.
Asked dealer about this and they said it could not be changed...
How does your e-brake work???!
Old Jun 20, 2017 | 11:57 AM
roy777's Avatar
2020 C63 Coupe
Yeah mine is the same. I had this on my C43, but not for the C63.
The only reason I can think of for this is the C63 is too much of a beast to just let loose without manual intervention.
Old Jun 20, 2017 | 02:23 PM
msd3075's Avatar
'15 C63S
Only thing I can think of is that the MCT transmission has something to do with it. The fact that it has a clutch that puts the car in 'neutral' (same as a manual transmission in 1st gear with the clutch pedal pushed in) versus a torque converter that doesn't have that separation might mean the e-brake is programmed to stay on until you are 'in drive' after pushing the throttle.
Old Jun 20, 2017 | 05:01 PM
auditoamg's Avatar
C63s
The only reason I can thing of for this is the C63 is too much of a beast to just let loose without manual intervention.
Thanks to you, both.
As long as everyone else's cars to do this I will, this one time, accept that it's correct.
Normally when a dealer tells me that every car on the lot does it so it's supposed to do that, I laugh and tell them: "So, by that logic, if every car on the lot didn't start...."
Old Jun 20, 2017 | 06:37 PM
BD-C63's Avatar
2015 C63S AMG
Mine's the same. I added the manual release of the e-brake to my start up procedure as I don't like the lunge you get when you touch the gas with the brake on.
Old Jun 20, 2017 | 06:47 PM
auditoamg's Avatar
C63s
I here ya.
I just "brush" the accelerator enough to blip the RPMs, and the e-brake releases.
