C63/C63S AMG
New Tyres - Michelin Pilot Sport 4S
Old 08-23-2017, 04:22 PM
  #51
M177ED1's Avatar
C63S EDITION 1
Ole
do you know the offset?
i just put 20x10 et45 with 295/30 Michelin PSS AND THE OTTER EDGE OF THE TIRE RUBS THE TOP INNER PORTION OF THE WHEEL WELL WHEN THE CAR DIPS QUICKLY.
Originally Posted by ole85
front wheels are 2pc Configuration with Hidden Hardware
Polished Candy Black & Gloss Clear
20x9 tyres msp 265/30/20
rear wheels are 2pc Configuration with Hidden Hardware
20x10.5 tyres 285/30/20
i want to try 295 soon
Old 08-23-2017, 04:25 PM
  #52
M177ED1's Avatar
C63S EDITION 1
Here is at least one limit.
20x10 ET 45
with 295/30/20 pilot super sports
*******g rub the tiniest portion on the inner well of my Sedan
even in S+ suspension
Originally Posted by RDO247
Wish someone would go to the limit on a sedan so I can get wheels for mine.
Anyone running 11's on their sedan???
Old 08-23-2017, 04:58 PM
  #53
RDO247's Avatar
C63S
Originally Posted by Star4life
how do you run a 295 safely on a 9.5j rim? most places say a 275 is largest you should run on a 9.5j.
You have the sedan correct? that came with 8.5j front and 9.5j rear. the front largest should be 255 and rear 275. doesnt going larger pinch the tire?
My tyres are fine.
Old 08-23-2017, 05:33 PM
  #54
RDOCA's Avatar
2016 C63S Sedan
Yes
Old 08-23-2017, 08:14 PM
  #55
RDO247's Avatar
C63S
Originally Posted by RDOCA
Yes
Have you run 295's on your rear?
Old 08-23-2017, 08:45 PM
  #56
Sanch's Avatar
AMG C63s
Originally Posted by M177ED1
Her is ear is at least one limit.
20x10 ET 45
You may need to drop the tire to 295/25/20 or go with 285/30/20
Old 08-23-2017, 11:11 PM
  #57
M177ED1's Avatar
C63S EDITION 1
What offset are you running?
It doesn't make sense to me how I have a 10" rim et45 and there are peeps running 10.5+?
Only thing I can guess is that the offset needs to be just a bit more.
If I can find someone with a 20" rim (10/10.5/11) that is running a 295/30 Michelin PSS and get their offset I can just shop around and still be able to use my brand new tires...
Old 08-24-2017, 12:31 AM
  #58
Sanch's Avatar
AMG C63s
Did you get a custom wheel where you could pick the offsets? - The wheel brand is the best people to advise you on this as they would be well experienced.
I have the coupe, not sure about the offsets on mine (shop took care of it). I'm running 20 x 10" in the front (275/30) and 20 x 12" (305/30) - With the new Michelin PS4S.
I wanted to go 325/25 but PS4S don't come in that size yet only PSS. I'll be switching to 325/25 once mine have worn out and the PS4S are released in that size. The 305/30 are nice but 325/25 would sit ideal IMO. Someone's got to try it
This is the current set up.
Old 08-24-2017, 06:03 PM
  #59
MarkC63's Avatar
2016 C63 Wagon
325 wide tyres
That is Porsche GT3 RS territory!!! Love it!
Old 08-24-2017, 07:26 PM
  #60
digitalnav's Avatar
C63S Sedan
So basically... once my PSS are dead i should get these new tires?
Are they good for the rain?
Old 08-24-2017, 08:16 PM
  #61
Bluetonic's Avatar
2017 AMG C63S Coupe, Triumph 675R Daytona, Triumph Explorer.
Thanks for this post!
REALLY looking forward to getting these fitted. I was a big fan of the MPSS2s and not too happy with the Conti's that came stock.
Will also be interested on stock fit F19"/R20" sizes.
Old 08-24-2017, 08:41 PM
  #62
RDO247's Avatar
C63S
I am recommending the Pilot Sport 4S's to everyone.
I had the Super Sports for a couple of days and returned them as I found them a little noisy on the highway and the rear end was still stepping out with the cars new found power.
Once the PS4S's were fitted there was a noticeable improvement in road noise and traction.
I havent driven to much much in the rain yet as Brisbane has been quite dry this winter but no issues when it has been wet which was yesterday.
Ive been down the quarter mile a few times now and only notice the slightest tyre screeching in first gear when pull off the start line.
Old 08-25-2017, 01:14 AM
  #63
Sanch's Avatar
AMG C63s
Best all around tire dry and wet... Def upgrade you will not regret it.
Tires are everything, you can really feel the difference when you but the power down.
Old 08-25-2017, 01:15 AM
  #64
Sanch's Avatar
AMG C63s
Originally Posted by MarkC63
325 wide tyres
Haha yeah, it's pushing it... but someone needs to try it!
Old 08-25-2017, 01:43 PM
  #65
RDOCA's Avatar
2016 C63S Sedan
No but it isn't what you run or what will fit without rubbing .
It is the correct size for the rim width.
A stock sedan rim is not wide enough for a 295. A 285 is the widest recommended and a 275 is preferred. If you want to keep the factory ratio the front widest is a 255 so you can only go to a 275 on the rear unless you go to a wider rim. I will be going to a 255/275 and the new Mich 4S.
With wider rims it opens the choices up but as some have found out the correct offset is a must.
Old 07-05-2018, 03:31 AM
  #66
eashwar63's Avatar
C63 AMG SEDAN 2013 (PP)
So I recently fitted new tyres after the old set of Dunlop's prematurely wore out due to camber and toe settings.
I spent a lot of time researching Semi-Slicks as I love the look of them but was worried about the road noise as this is our family everyday car.
My tyre shop replaced the Dunlops with Michelin Super Sports which I drove on for about 3 or 4 days.
The Super Sports were a definite improvement over my worn Dunlops traction wise, however, I noticed that they were a little noisy on the highway.
Traction wise as stated above, they were a lot better than my worn Dunlops but still could manage to break traction from a standing start and flooring it in the low gears up to 3rd.
My tyre shop offer a one month return on Michelin Tyres if not 100% happy with the performance so I returned the car and had the Pilot Sport 4S's fitted no questions asked.
I got to say that these 4S's are absolutely brilliant when it comes to controlling my 382kw/atw & 882 nm.
I'm still playing around with different situations we're my old tyres would break loose but first impressions are WOW with a big smile on my face.
I'll give more feedback as I drive some more but for anyone needing new tyres or wanting more traction I highly recommend the new Michelin Pilot Sport 4S.
Size wise, I'm still running factory black cross spoke wheels with 295/30/19 on my rear and 265/35/19 on the front.
Will these be good for only street driving?I want good grip and mileage out of them.Right now I am running 19 inchs with Yokohama Advan s sport, the grip is OK but the ride quality is very bad....
Old 07-05-2018, 03:53 AM
  #67
LARSLEMANS's Avatar
2008 C63 AMG
I totally agree with you on the recommendation of Michelin Sport 4S. They have an amazing grip and an acceptable noise level.
Old 12-27-2021, 11:00 PM
  #68
shane060's Avatar
M3
Looks great! Is this on the sedan ? Any issues bumping yhr size up to the max on the front and rear? I'm wanting to do the same but not lowered so wondering what would be best like 265 35 / 295 30 or 255 35 285 35 to fill in the arches more ?
Old 12-27-2021, 11:08 PM
  #69
shane060's Avatar
M3
So how is it he is runnig 265 35 ane 295 30 with no issues and bumping the sizes to the above max recommendation with no issues or concerns ? It looks great and I'm looking to go the same route but keep seeing everyone saying go 255 35 285 35?
Quick Reply: New Tyres - Michelin Pilot Sport 4S
