Battery tender
CTEK makes the best battery chargers.
Lighter adapter is NOT on all the time.
There are terminals under the hood. All this info is in the instruction manual.
I use the one by CTEK. Over the past several years has not let me down. Swedish company, made in China.
I've hooked it up both ways. Direct to the battery and at other times to the terminals under the hood. The terminals are a bit more convenient.
2015 C300 4Matic Sport
Take care
The CTEK 4.3 can go up to 15.8 volts during desulphation and recond steps. My 2011 C300 manual says 14.8v max for chargers.
If you are going to leave the battery connected while charging, I would be cautious. The 3300 looks safer for this method. Also, some newer cars have lithium batteries. You will need a CTEK lithium charger.
https://smartercharger.com/wp-conten...al-mus-4.3.pdf
