C63/C63S AMG
Who's Upgraded their Turbos
Old Oct 22, 2017 | 02:15 PM
CarHol's Avatar
MB
Originally Posted by DSawyer63
I am running the Dime Racing Stg. III turbos and they perform flawlessly. I did 10.48 in the 1/4 Mile with full interior and the engine has a very linear and factory like powerband, yet it still has a brutal kick when you stomp it. The best part is the car drives and delivers power exactly like factory when in comfort mode which is very impressive for a 700 WHP car.
how you do 10.77 @ 129 then 10.48 that a big change. you put something else to make faster?
Old Oct 23, 2017 | 11:56 AM
PL27's Avatar
x
doug has a driver mod and a proper tire setup, skinnies in the front and 18” hoosiers in the rear
Old Oct 25, 2017 | 12:29 PM
Mr. Pink's Avatar
W205 c63s AMG
@powertechnik on IG has the recipe.....
Old Oct 25, 2017 | 01:25 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
OEM E63S twin scroll manifolds and turbos both bolt onto the C63S because the cylinder heads are the same. So that would be the easiest “OEM” turbo upgrade for the C63S. The oil/coolant lines to the turbo may need to be modified, but it’s possible even the standard ones will fit.
Someone needs to try this out, I can’t even imagine how insane the power down low and up top would be with the larger twin scroll turbos. This is probably the setup the C63R or Black Series or whatever they end up calling it will be.
Old Oct 25, 2017 | 01:38 PM
Chigs's Avatar
2018 C63S Sedan
Talking
I imagine it would as "insane" as the E63S
Old Oct 25, 2017 | 04:50 PM
RDO247's Avatar
C63S
Manifolds would be the hardest to get hands on...
Turbos can do aftermarket.
We need to get a big tuning shop to delelope some twin scroll manifolds that will mount turbos infactory location and won't crack.
Old Oct 25, 2017 | 04:52 PM
  #32
RDO247's Avatar
C63S
Photos, Dyno Graphs, Time Slips???
Old Oct 25, 2017 | 05:30 PM
  #33
AlexZTuned's Avatar
2017 Porsche 911 C4
E63S manifolds part number: A1771400100
Old Oct 25, 2017 | 05:33 PM
  #34
RDO247's Avatar
C63S
I wonder how much these would be through parts???
Old Oct 25, 2017 | 05:52 PM
  #35
digitalnav's Avatar
C63S Sedan
https://www.mbonlineparts.com/auto-p...ine-parts-scat
C63s Manifold looks like its only $360ish?
Old Oct 25, 2017 | 06:13 PM
  #36
RDO247's Avatar
C63S
Is there a part no. for the other side?
Old Oct 26, 2017 | 01:29 AM
  #37
KEMA's Avatar
2012 E63 PP, 2012 Ferrari 458, 2012 Boxster S
Minus approximately 600 lbs in curb weight...
Old Oct 26, 2017 | 07:02 AM
  #38
tekfoc's Avatar
Veteran: Army
18 E63S
Your looking at intake manifold
What we’re looking for is exhaust manifold.
Old Oct 26, 2017 | 07:49 AM
  #39
RDO247's Avatar
C63S
What we €™re looking for is exhaust manifold.
No turbo manifolds listed in the website.
Old Oct 26, 2017 | 12:24 PM
  #40
PL27's Avatar
x
new e63s isnt “insane” my upgraded turbo c63 beat a tune only pump gas e63s with 630whp/680wtq , i put a couple of cars on the e63s by 130 starting at 60. I don’t post stuff here because nobody seems to be interested 🙂
Old Oct 26, 2017 | 12:45 PM
  #41
AlexZTuned's Avatar
2017 Porsche 911 C4
From what I understand, deliveries literally just started for the 2018 W213 E63S. You sure you didn't race a last gen W212? The E63S traps at least 126 mph stock, so tuned it should be 130 mph or more. That's about what a "good" running C63S with a turbo upgrade runs. And forget about keeping up with one from a dig...
Old Oct 26, 2017 | 01:01 PM
  #42
PL27's Avatar
x
my c63s trapped 133.8 in the 1/4 mile with 80F, 1800da, 60% humidity. And yes my good friend Mo from dmeTuning got his edition one e63s and already tuned it. I definetly know my benz apart from each other.
Old Oct 26, 2017 | 01:05 PM
  #43
PL27's Avatar
x
here you go w212 e63 vs my c63s 😂😂
Old Oct 26, 2017 | 01:06 PM
  #44
PL27's Avatar
x
When i raced him he had 630whp/680wtq then went to the dyno and revised his tune to make more power
Old Oct 26, 2017 | 01:29 PM
  #45
AlexZTuned's Avatar
2017 Porsche 911 C4
Nice, do you think you would keep up with it after the revised tune? Be interesting to see how you would do against it on pump gas like he was running instead of race gas...
Old Oct 26, 2017 | 01:37 PM
  #46
PL27's Avatar
x
i run race gas because of my tune. High timing and about 24psi, if i run pump gas im significantly slower. I use it because i HAVE to use it. 20whp / 30wtq increase will not make a drastic difference and i will still win by alot. If you’re not tuned for race gas theres no need to be using it.
Old Oct 26, 2017 | 02:43 PM
  #47
AlexZTuned's Avatar
2017 Porsche 911 C4
Wait, so you run race gas 100% of the time? What are your numbers (dyno and 1/4 mile trap) when you run on pump gas?
Something tells me that pump gas tune only E63S would have stayed pace and even passed you if you were running the equivalent octane. Not exactly an apples to apples comparison when you don’t have to worry about detonation and knock with all that high timing and boost.
Honestly, the E63S with a properly optimized
tune on pump gas with bolt-ons (downpipes, filters, exhaust, etc) is probably going to run as fast if not faster than your setup. Throw race gas in the E63S with bolt-ons and you’ll be seeing its taillights even with your upgraded turbos and race gas.
Old Oct 26, 2017 | 03:15 PM
  #48
Chigs's Avatar
2018 C63S Sedan
Race what ya brought.
Old Oct 26, 2017 | 05:03 PM
  #49
RDO247's Avatar
C63S
Is DME Dime???
What mods have you got and what's your hp/tq atw with your current setup?
What race has do you use?
Is is it available at your local gas station?
Old Oct 26, 2017 | 07:13 PM
  #50
Chaser123's Avatar
C63 s
Getting these fitted next week slightly bigger then E63 turbos
