C63/C63S AMG
Help Removing Grill ed1 coupe
Old Oct 25, 2017 | 06:25 PM
Blackslk55's Avatar
2014 E63 AMG, 2012 C63 AMG & 2008 SLK 55
Hi
need some help with removing the grill from a c63 coupe, I want to have it painted black, the paint guys tell me that the bumper needs to be removed however I am pretty sure I read somewhere that it should be able to be removed with out the need to drop the bumper.
Any help would be much appreciated.
Tony
Old Oct 25, 2017 | 07:13 PM
Bobby li's Avatar
c63s coupe
Hi black. I have the same question as well, I want to paint it Matt black.
Old Oct 26, 2017 | 12:07 AM
Jeff Whitten's Avatar
AMG C63S
From other threads, it is confirmed to get to all the clips that hold it on, you do have to remove the front bumper.
Other option is Plasti-dip which can be done with it on the car. If you are going with flat or semi-gloss black, this is a good option. If you want high gloss look, you will need to remove and it paint it.
Old Oct 26, 2017 | 05:20 AM
ole85's Avatar
c63s
i just removed it 1 month ago and tried my hardest to remove it without removing the bar but at the end i removed the bar its impossible to remove without removing the bar
