C63/C63S AMG
C63s sedan with coupe wheels
Old Oct 3, 2018 | 11:28 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
The only issue will depend on how low you are and when turning sharp the tire may contact the inner fender wheel opening at the top . Mine touch slightly and have worn the paint off bit on the inside
Old Oct 3, 2018 | 11:34 PM
C3504matic's Avatar
these rub slightly when turned sharp. These are 9.5's but sitting about the same as your rims
Old Oct 4, 2018 | 08:17 AM
RDO247's Avatar
C63S
Ok, front Coupe 9” wheels & Continental 255/35/19 fitted to my sedan.
They look really good and fill the guards perfectly.
I checked the inner guard to tyre clearance which looks good to, plenty of room when at full lock.
Inner guard clearence looks more than sufficient.
Took it for a drive in the to see if there’s any scrubbing, no scrubbing at all.
I think I will now get my PS4S’s fitted to see if they scrub as there 265/35/19’s.
As it sits now, I can confirm that factory front 19x9” et 25 Coupe wheels and tyres fit with no issues to my sedan.
Old Oct 4, 2018 | 11:00 AM
dbvolz's Avatar
2018 C63s
Any more pics of the back and how the fitment is?
I'm super close to pulling the trigger on some coupe 19/20 wheels for my 18 sedan, and want to be sure it's the right fit.
Also, I'm assuming you're not lowered, and on stock suspension?
Old Oct 4, 2018 | 04:33 PM
RDO247's Avatar
C63S
Havent got tyres for the rear yet.
Im lowered 20mm front and rear with KW HAS.
Old Oct 5, 2018 | 05:52 AM
RDO247's Avatar
C63S
Ok, front Coupe 9” wheels fitted with 265/30/19 Michelin Pilot Sport 4S’s confirmed and fit perfectly.
What a difference in look.
Old Oct 5, 2018 | 10:12 AM
  #32
dbvolz's Avatar
2018 C63s
Thumbs up
Looks fantastic!
Old Oct 6, 2018 | 04:33 AM
  #33
RDO247's Avatar
C63S
Looks fantastic!
Thanks, I didn’t realise how much better it was going to make the stance look.
I was was just trying to get extra wheel width for my wider then stock tyres.
Just need to to sort the rears out now.
Old Oct 15, 2018 | 05:39 AM
  #34
milan25's Avatar
C63 s Edition 1 Sedan
How is the fitment for the rear tires working out? and is it better for clearance without lowering the car?
Old Oct 15, 2018 | 05:55 AM
  #35
RDO247's Avatar
C63S
Scapped this project for the moment as my tyre choice isn’t going to work.
I only want to run 295’s as that’s what I am running on my factory 19’s.
I’ll keep the coupe fronts on for the moment as they fit perfect.
Will look at AM wheels in 19x10.5” & 9”.
Old Oct 24, 2018 | 09:03 AM
  #36
Zeek1's Avatar
W205 C63s
could you get 295's to work on coupe rims?
Old Oct 24, 2018 | 04:28 PM
  #37
RDO247's Avatar
C63S
No mate.
Fronts were perfect fit with the Michelin PS4S 265/35/19, however, the rear wheel fit great but I couldn’t match the tyre size I wanted to use.
I run a 295 currently on my 19’s and wanted to stay with a 295 for the added width for both traction and look.
A 295/30/20 has a 1 inch increased rolling diameter over the 295/30/19 which makes this tyre size illegal hear in Australia (max rolling diameter increase of 14mm allowed).
A 295/25/20 load rating was under factory spec so I wasn’t willing to chance fate with this size either.
Also, I could get my hands on a tyre to trial fit guard clearance which I was most worried about.
I could have have run with a 285 but like I said I needed/wanted to stay with a 295.
I know my current 19” tyres fit so I thought it would be easier to have a set of wheels built.
Now just need need to confirm offsets.
Old Nov 26, 2020 | 11:35 AM
  #38
Dany1337's Avatar
W205 C63 AMG
So if i use the coupe rims with smal tyres (sedan size) can i lower the car then without rubbing?
Rear: 20x10.5J ET57 with 275/30/20
Front 19x9J ET25 with 245/35/19
Old Nov 26, 2020 | 05:18 PM
  #39
RDO247's Avatar
C63S
Coupe factory wheels and tyres will work on a lowered sedan. I was trying to go wider tyres, 295, for better traction.
If I fitted 295 on the 20” wheels the profile would have been 25 which wouldn’t work for me.
Old Dec 3, 2020 | 01:23 AM
  #40
Blaque Diamond Wheels's Avatar
Former Vendor of MBWorld
2014 S63
Hey guys! Sharing our customer's love for his new wheel set up on his Edition 1
We hooked him up with some clean Frozen-Silver finished BD-11s in 20s
Just click on the images to view our full gallery on this project
Just send us a PM or you may contact us through the following:
Phone: (818) 362-2300
E-Mail: Info@BlaqueDiamond.com
Visit our website and check us out on Social Media:
Website: www.blaquediamond.com
IG: @BDWheels
FB: /BlaqueDiamondWheels
Old Jul 12, 2023 | 06:44 PM
  #41
DylanC63's Avatar
c63
I just got a set of coupe wheels for my 16 sedan, this is the setup I’m going to go with.
Rear 275/30/20
Front 245/35/19
I’ll let you guys know how it works out.
Old Jul 12, 2023 | 07:50 PM
  #42
Belong's Avatar
W205 C63S T
Rear 275/30/20
Front 245/35/19
Go with 285 30, the 275 30 is skinny compared to the 245 35.... rears will easily fit.. im running 285 30 lowered on a 10.5x20 ET 45!!
Old Jul 17, 2023 | 02:55 PM
  #43
DylanC63's Avatar
c63
Came out looking great, no tire rub at all. I think I may have been able to go up to 285 in the rear.
Old Jul 18, 2023 | 05:42 AM
  #44
Belong's Avatar
W205 C63S T
Do you even read what people are replying here????????????
