AMG Academy At COTA (DRIFT)
Lunch: was quick and again similar to the AMG academy eventsSlalom: set up 4 cones in a straight line. Point here was to learn how to kick the back out and then bring it around the other way. Also how to use the brakes to quickly end a skid. At the fourth cone you did a 180 and came back the other way. Drift course: this basically put everything from the day together with one added bonus “the garage”. Couse started out with a slalom that lead into the figure 8. After coming out of the last turn you had to spin a 180 and roll backwards into a large square marked by cones. At 4pm both teams met up at the drift course and it was time for the Competition. You had 2 chances to do the drift course getting as many points as possible. You had to get a slide at each of 5 cones for points. You were judged on the best of the 2 runs. This was over by 4:45 and headed inside for the results and a refreshment before leaving. Our team ended up winning the team trophies and I managed to get first place and getting a shirt and a Leather duffle bag. I personally thought the entire event was a lot of fun. It’s not done on the actual track so doubt that the one at Laguna Seca is much different. They wet down all the tracks so while you are learning the “drift” its only on wet roads. I can see how it’s a hit or miss for some people. Drifting is one of those things that takes a lot of practice, so if you have not tried it before or played around in the snow before don’t expect to walk out a drift master. There will be a lot of spinning out and fighting understeer during the day. The instructors make it look so easy so when you try it you are expecting to just slide around with no issues. The last thing I can say is that if you go make sure you take a ride with the instructor. Being able to see how they use the wheel and feather the gas and brake first hand makes it easier. After my ride along I realized that I was giving it WAY too much power. Anyway hope this helps anyone considering it.
We did a skidpad/drifting course in the C63S Coupe (felt like home), and most people were swapping ends. Once I got the hang of it, it was a ton of fun steering with the throttle and feeling the rear diff working its *** off... but like you said, it's not easy!
Do they give you any opportunity to learn/practice how to drift around a corner/sweeping curve, hold/maintain the drift, and then recover and accelerate out? You know...the fun part hehe
there was a ton of swapping ends all day. as you know its a delicate balance of steering brake, and throttle.
BTW congrats on your P1 on the time trials!!
the figure 8 is more like 2 drift circles you can go around one a few times and then accelerate out.
In the US, the AMG Driver's Package is only provided when you purchase an "S" model (C63 S, E63 S, etc etc). It basically provides you with two things:
1. Increasing the electronic limit from 155 mph to 180 mph (I can vouch for this
)2. Access to the AMG Driving Academy with a substantial discount.
Awesome! Wanted to make sure, as that was one of the really important aspects for me.
ANY purchase of an AMG vehicle gives you a 1 day credit for the AMG academy see here.
https://www.amgacademy.com/register/...urchase-Reward
I know this since some people did the basic earlier that week after purchase of a CLA. You can also ask the c43 guys as they now get it included(or look in thier sub-forum)
If you register for a Private lounge ID (maybe this is S models only) then you can get a discount on the AMG driving academy. believe its 20%
The Driver's Package is standard for "S" AMG models, however, and in addition to the AMG Academy credit you mentioned, it also raises the electronic speed limit as well.
