Glove box weird issue with handle
Have any of you noticed when you use the valet key to lock the glove box, the lever handle with the key hole dangles outward and is loose? Once you re-insert the key and unlock it, it opens and closes normally, but the lever handle is in place. Don't know if this is something normal on a C63 w205. It's kind of annoying and super obvious for someone peaking around your car that you have locked the glove box.
This happened to my car. Took it into the dealership and they replace the glove box door under warranty. Kind of annoying. They said something about the spring that holds the latch in place when in the locked position failed.
Honestly I don't know. I was taking my car in for another reason, I pointed it out to my SA and he said they replace the whole glove box door. Its taken care under warranty. If it doesn't bother you that much leave it alone until you have bring your car in for a service or other reason and point it out to them. If your more of a DYI guy I just don't know. sorry
'15 C63S
Funny thing is maybe a week or two after I bought the car I had a strange noise coming from the glove box. It's like something was rolling around inside the glove box but nothing was in there. Tracked down the noise's location, and it was coming from inside the door. It went away after a few days and never came back so there was never a need to have it looked at by the dealer. I'm willing to bet I had the same spring failure and the spring it either lodged inside the door somewhere or it worked it's way out somehow.
