C63s 205 engine ecu location?
Greetings Mb massive,
Where is the location of the engine ECU? Also the S ecu is pre programmed for more power is it not? Thus if it was dropped in to an non S would it up the power / torque? Just code it in?
I know where there is a mangled one being broken you see...
Give it a try and let us know! 🤣
You may have some errors given that the differential is different and active engine mounts are obviously absent in the non-S models. An S-model ECU will probably start freaking out haha
Borrocks!! i never thought of that!! I was hoping the engine ecu was engine only!! O well its off to GAD or MSL : )
Just need some sport cat down pipes now that dont require pulling the transmission to fit them!
I opted to to keep my down pipes in tact so trans came out.
