Transmission Fluid Flush
Has anyone gotten their transmission fluid flush done at 30k miles or more? If so, how much did you get it done for? I am also looking for a DIY on this. Does anyone have a detailed instruction on how to get this done? Thanks in advance
Mines has 35K miles and had a A service done. My next service would be a B service. probably brake fluid flush needs to be done. Don't know if its time for tranny flush, but I have heard its usually recommended around 30K. I'm wondering if that's a SA recommendation or Benz recommendation.
JaeJin Sohn (02-21-2018)
and that was just for the service, not a flush.. typically a dry, new system will hold about 10-12 quarts of transmission fluid. At most they pumped in 6 quarts of fluid after replacing the filter and then letting it dilute into whats left of the old fluid after draining the pan. At that point they warm up the car and let the over-filled amount drain back out until the fluid is at proper levels. I have yet to see anyone actually flush the system unless they are cleaning out contamination.
