C63/C63S AMG
Question about Rotors/pad making noise
Old May 16, 2018 | 02:43 PM
kesmarc's Avatar
C63S AMG Sedan
Hello, i Have a 2015 C63S sedan W205. my car has 15k miles on it, when i brake from 20-0mph they sqweek like crazy. I did go to the dealer and they said pad were still 60% good and 30% in the back. why is this making all that noise at low speed? should i change pads and still be good for a good amount of time? thanks
Old May 16, 2018 | 04:21 PM
JaeJin Sohn's Avatar
2015 W205 C63S, 2015 328i xdrive, 2008 Mercedes R-Class 350, 2009 Hyundai Equus
I also have the same issue regarding pads making squealing noise at low speeds. I assume it's because of the aggressive pad material. I'm very used to driving modified cars with aggressive pads so it doesn't bother me as much. However, if you are willing to pay for it, there are many other aftermarket pads available that will reduce the squeal and dust. There are many forum posts regarding brake pads so look around.
Old May 16, 2018 | 04:58 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Perfectly normal for this type of brake/pad. Mine has developed a squeak coming to a stop also. You could always try rebedding by doing several back to back high speed stops, it'll deglaze the brakes and remove any deposits.
Old May 16, 2018 | 10:54 PM
AMGWagon's Avatar
2016 C63 AMG Wagon
I find the squeal develops as the brake dust builds up. If you give the discs and pads a good water blast the squeal should go away for a while.
Old May 17, 2018 | 03:21 PM
Chigs's Avatar
2018 C63S Sedan
I can't hear the squeal over the downshift exhaust pops and bangs.
Old May 17, 2018 | 07:33 PM
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
I have the ceramics. They squeak at low speed. Such is life.
