What wire to tap into for subwoofer
So after alot of searching on how to do this I have completed everything and all I need to do it hook up my line to the amp. Tried to read the burmester wiring diagram but tbh I have no idea how to translate that into anything I can use. Audio shop near me quoted me at $150 to install a single wire so i would rather do it myself does anyone know what wire to tap into?
From the Burnester diagram,
Pins 3 (+ pink/blk) and 15 (- pink) are for the left front footwell sub and
Pins 4 (+ violet/blk) and 16 (- violet) are for the right front footwell sub.
They will be at speaker level (not line level) so depending on what kind of amp you’re running it to you may need a line output converter to take the speaker level back to a line level for your amp first.
