Tire Pressure Low Warning?
Anyone having problems with Tire low-pressure warning light? I have the darn light on and all my tires have the correct pressure. I guess I will have to go get some warranty work done.
'15 C63S
Using the buttons on the left side of the steering wheel:
Home Button
Up 3 times
OK
Down 1 time
OK
This gets you to the tire pressure screen in the gauge cluster screen.
If you press Down when on this screen, it will bring you to the reset screen. Make sure the pressures are where you want to set them at, and follow the directions to reset the TPMS light and set the pressure you want it to run the lights off of. It'll set the light off whenever you drop below a certain percentage (something like 75-80%) of the set pressure.
Home Button
Up 3 times
OK
Down 1 time
OK
